Question about Sony KP-43T70 43" Rear Projection Television
No color The T.V. was working fine a few days ago. When moving it it was bumped very lightly against a wall. The color became distorted. Now it has no color at all, just black and white. Is there anything I can do to fix it?
  • 1,476 Answers
Since you say that this happened after moving the unit (and bumping it into a wall) it would seem to be worth looking at all interconnections from board to board to make sure that they are seated securely and properly. It could be as simple as a loose wire. If you don't find any problems with the connections I would look for broken solder joints on all boards paying close attention to the video board. A magnifying device will be necessary for this or you could resolder all the connections on the video board, if you know how to properly solder. Remember safety either way. If neither of these suggestions work you will probably need a qualified tech to find the problem as it could be just about anything. Good luck.
Posted on Jul 05, 2006
I have a 50DX10B, I believe was manufactured in July 2002. About a month ago the screen became distorted out of no where while I was watching it, and I gave the screen a little smack, (probably not the...
Replace or resolder your convergance IC's. What is a common problem is over time the heat emitted by the chips weakens the solder joints on the circuit board. If your lucky just a resolder job is all it needs.
Sep 04, 2011 | Hitachi 50DX20B 50" Rear Projection...
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here:http://www.discount-merchant.com/SearchResults.asp?Search=BP9601472A Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Apr 12, 2010 | Samsung HL-S5086W 50" HDTV
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
I have a 1/2 hp craftsman opener, it has the premium wall console, keyless entry and two remotes, chain driven. I installed it about a year and a half ago, it's worked fine since. Just recently, it would...
I would pull the logic board and check for loose or missing connections/traces on the printed circuit board. You can also foll the 110v line and make sure it has not worked loose.
Nov 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Seems there may be a loose wire or something. ABS & Traction Control lights go on for days then go out and everything is fine for a few days before this happens again, over and over. In this time the...
Hold your computer against your venture VAN while reading this, I can fix it that way... c'mon, take it to the dealership and quit trying to get something done for free. You need a wheel speed sensor or harness.
Jul 21, 2008 | 2004 Chevrolet Venture Passanger
Sporadic Discoloration & Distortion
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Mar 22, 2008 | Acer AL1912B 19" LCD Monitor
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Sony KP-43T70 43" Rear Projection Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
