Question about Car Audio & Video
2002 ford mustang-cd player says cd error and won't work- cd stuck in it?
How to remove face plate and manually check cd player for stuck cd?
  • 2 more comments
  • Jbecoop Nov 03, 2008
    Yep, same problem! If I keep hitting the CD button, after about 250 tries, it seems to go back to normal. For a while. Then it starts all over again....very disturbing as the sound is great when it works and of course, never sure when it will happen.
  • Anonymous Dec 21, 2008
    tried to eject cd and it did not come out and now the cd player will not play or eject any cds
  • Anonymous Mar 16, 2009
    yeah i have the same exact problem
  • Anonymous Apr 21, 2009
    Sadly I have the same problem in my 2002 Mustang V6 Convertible....Tried ejecting CD #4(other banks were empty) and it got stuck. Door is stuck open and the CD is stuck inside somewhere.
    Nothing plays now, I just get "CD Error". If anyone knows how to fix this (my car is in mint condition short of this!) I would appreciate it.
    Otherwise I am looking at replacing the whole unit which seems like such a waste.
MY 2002 GT HAD THIS PROBLEM! ALL YOU HAVE TO DO IS DISCONNECT THE POSSITIVE SIDE OF THE BATTERY FOR A FEW MINUTES AND REATTACH IT. WHEN YOU GET BACK IN THE CAR THE CD WHILLE BE HANG OUT OF THE CD PLAYER! I DON,T KNOW WHAT CAUSES THE PROBLEM, BUT MINE SEEMS TO DO THIS WHEN IT IS HOT OUTSIDE (95 OR HIGHER) WELL I HOPE THIS HELPS SOMEONE!
Posted on Aug 04, 2009
I have this problem quite often. I usually have to remove the unit, unplug all wires that are attached to it, and then connect all the wires again. This procedure seems to 'reset' the unit, and it usually works once more.
-Billy
www.goodpersontest.com
Posted on May 26, 2009
Cd stuck reject button won't work
Look at the face plate of the CD drive, if it has a small hole located under the tray straighten out a paper cilp and stick it in the hole to preform a manual eject. Remove any disc inside and close it. Now try to open it normally. If it still does not work it is time to buy a new cd drive.
Aug 06, 2011 | Computers & Internet
I HAVE A 2002 MUSTANG GT. THE CD PLAYER IS MESSING UP AND HAS BEEN FOR A WHILE NOW. IT KEEPS TELLING ME CD ERROR AS SOON AS IT IS STARTED. IF I PUSH THE LOAD BUTTON IT TELLS ME ALL THE SLOTS ARE FULL, BUT...
Sound like the cd player itself has the issue. It will have a small sensor in the player to tell the user if all the slots are full with cd's or not. thats either gummed up or blocked from doing its proper job. as far as the cd error goes, thats your laser. If its still the stock 6 disc cd changer, its a good time for you to concider changing out that cd deck.
good luck bro
May 20, 2011 | 2002 Ford Mustang
CDs are stuck and CD player will not work. Factory six-disc radio. New CDs.Third new factory radio with same problem. Any ideas on getting the CDs out?
From everything I've heard, this is a very common problem and can be costly to have repaired. One forum I found had this posting...maybe it will work for you.
"This is what I did to my In-Dash 6 disc CD Player.
Rather that toss the radio like most are saying to do you can try this first.
Pull the radio out and remove the screw on each side and the 2 on the back. Pop off the cover and you can see the CD's. The part of the CD changer may have not fully engaged the CD it wanted to play and it is stuck not knowing what to do. Press on the CD that so that the part that spins the CD is locked into the center of the CD. Leave the top open and plug in the CD player. It should start going through all of the cd's then if the CD error is gone it will play again."
Jul 31, 2009 | 2002 Ford Mustang
6 Changer cd player
to take the radio out you need to remove the big plastic piece around it. to get the radio out there is a special key that fits into 2 little holes on the side of the head unit.
Jun 04, 2009 | 2002 Ford Mustang
6 disk cd player error
This is a part failure in the mechanism that loads and ejects the disk, there are no repair manuals avail to either the tech or the consumer, the only place that the factory gives this info and parts to are factory authorized repair stations, bottom line you must pull the deck and contact a Ford dealer in your area for location of the nearest factory repair station. I was dealer tech for 20 years and that is how it is done.
Nov 21, 2008 | 2002 Ford Mustang
CD changer reading "CD ERRor"
reset your radio by unplugging your battery for an hour and plug it in to see what happens. if not then time to replace. these cd players look nice and all cuz they are 6 disc but dont read mp3 well and get stuck easily with thicker cds
Oct 03, 2008 | 2002 Ford Mustang
Cd player
does the face come off the cd player detachable the little reset is behind the face and if u press that the cd will eject
Sep 16, 2008 | 1998 Ford Mustang
Sanyo FXCD-500 RB CD/Cassette
Judi -
Please go to your posting titled "Stuck CD" - I am attempting to help you!
smartsolve
Jul 05, 2008 | Sanyo FXCD-500 RB CD/Cassette Receiver...
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Car Audio & Video Logo
2,792 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
