Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting an error code F/H but it works most of the time. Then it just quits
  • 750 Answers
Hello lilo1
Welcome
You said, You are getting an error code F/H but it works most of the time. Then it just quits
You may have low water pressure which the machine senses and after some minutes will shut down .
If any pump runs with insufficient water pressure it will burn out the pump so washers are made with auto shutoff's in those case it does shut off.
Check that the water valves are passing water out of the taps that are connected to the washer and they did not fail.
When you remove the water supply hose from the washer inlet, you will probably find the screens in the washer water inlet are blocked and need to be removed and cleaned off and then replaced.
Do not bend them up and you can re use them!
Below are causes and more remedies
Let me know how it goes!
Huuum
Please remember to leave a rating?
F/H Error code
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Posted on Oct 20, 2008
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
The waher quits working and F33 shows up on the front
F33 error code indicates a pump drive system error.
If the pump ohms out correctly and the harness is secure and working fine, I recommend replacing the CCU (central control unit).
Good luck.
May 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Get the code F-01 on the whirlpool duet front loading washer, not sure what this code means
Click this link directly:--- http://mymoremoney.blogspot.com/2011/01/whirlpool-duet-ghw9150p-front-load.html --------------- In this there is instructions and procedure mentioned to resolve the issue. If any part checked out faulty then you can get it from www.repairclinic.com .----------- Thanks.Helpmech.
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer with an f du error code. do you know what that means
That's a door unlock error. The machine will display that code when after trying 6 times to unlock the door, it still won't unlock.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer won't start
The error codes it is showing don't even exist. Does the little round door latch plunger go in and out if you push it?If not, then replace the door latch. If so, you most likely have a bad machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
