You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
or you may
use the system configuration Utility Method.
Windows Xp:
If Windows
XP is the only operating system installed on your computer, booting
into Safe Mode with these instructions.
To use the
System Configuration Utility method
Windows
as part of a multiboot system
When you are finished with troubleshooting in Safe mode, open MSCONFIG
again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK
to restart your computer
Use this
method ONLY if you have multiple operating systems installed on your
computer.
Windows Vista:
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
