Machine is about 20-25 years old and can't find manual to use it again, it is in great working condition but I have forgotton how to load bobbin etc. hope you can help
SOURCE: I have a Janome 9000. I was winding a bobbin and
Is there thread caught in the bobbin winder?
SOURCE: janome jd 1822 when i'm doing zig zag, the thread
rethread the machine getting every thread guide
check the thread tension 3 or 4 is usually good
Change needle--make sure the flat side is toward the back of the machine & that it's insert as high as it will go--make sure the needle bar is raised to it's highest position
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin that the bobbin is wound correctly & put into the bobbin case or shuttle correctly
here a tip about needle & thread compatability
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
