Question about Garmin GPS
Hi i have a problem with my Garmin GPSmap 76CX. It is only work when it is plug with the usb cable. it doesn't work with the battery or the 12 volts cable? Can you help me
  • francois478 Oct 20, 2008
    hi i can use 2 AA batteries too and before it was working but now nothing on both sources 12 volt cable and the batteries.
    Genius:
  • 3,422 Answers
It is not the battery,the problem is with the 12 volts cable.Please buy a new cable and then your Garmin will charge even with the cable.
Let me know the result
Posted on Oct 20, 2008
My garmin 530hcx has locked up on the opening screen...is there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 | Garmin GPS
Hi... I lost my driver for gpsmap 76cx, if anyone can help me how i can solve this problem?
Try downloading it from here:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00468-00&cID=167&pID=350
May 04, 2011 | Garmin GPSMAP 76Cx GPS Receiver
Unit makes sounds but no display
Hi
If unit is as per pic I assume it has external antennae. Ensure the multi pin plug is secure in the rear of the unit and also use a fully charged 12 volt battery, Has it been working before?? Usually a rear plug problem. How old is unit. Just had a another thought, check that the polarity is correct, ie pos wire to RED (Pos) on battery. Very polarity sensitive.
Cheers cbacer
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
Garmin Maps
No, Garmin maps will not work on a Magellan Triton.
Yes, you can install Bluechart and CityNavigator onto one SD card. Inside Mapsource, select the Bluechart maps you want, then switch to CityNavigator and select the maps you want from then, and then send all at once to the GPS unit. If you send Bluechart maps, and then CityNavigator, the CityNavigator will overwrite the Bluecharts. This is why it must be done all in one step.
If this solves your question, please remember to come back and rate the answer.
Apr 21, 2009 | Garmin GPSMAP 76Cx GPS Receiver
How to unlock the mapsource?
You get an unlock code when you buy a map from Garmin. Go to garmin.com
Peter
Jan 27, 2009 | Garmin GPSMAP 76Cx GPS Receiver
I would like to install a north america maps to my Garmin bought in italy withy europe maps
You would install the maps on an SD card, or microSD card, and then inside the setup of the GPS unit, you would choose which maps you want the unit to display.
Sep 08, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Registration
If he purchased it from a Garmin dealer, return it and have it exchanged for an unregistered unit.
Apr 18, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Cracked Screen on my Garmin GPSmap 76Cx
Sorry, that's beyond my scope. You might want to ask on some of the GPS forums.
Apr 01, 2008 | GPS
Using a DGPS on a 76csx
there is no possibility to use DGPS with 76csx... due to the fact that 76csx receivers use chipset the 'sirf star III' series and this chipsets don't allow use any RTCM data.
regards,
frankie, poland.
Feb 02, 2008 | Garmin GPSMAP 76Cx GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
