Question about Sport & Outdoor - Others
Exercise Bike Proteus PEC-4350HP
Hi there, I was hoping someone there might be able to help me troubleshoot my issue with my above machine. I have had this now for 3 - 4 years. The issue is that my monitor displays "E I" and beeps at me. It does not let me get into any training modes whenever I try, and sends me right back to a blank screen saying on it "E I" and beeping. Please help me troubleshoot this? Thanks kindly.
The Boffin
  • 3 Answers
SOURCE: Monitor displays breifly then goes to blank screen
Well my Acer AL1711 finally gave up in as much as the screen flashed briefly at switch-on then went blank, regardless of brilliance setting so I decided to take it apart and try to fix it. The good news is that IT WAS NOT THE LAMPS that I feared in my earlier post and was easier than I had ever dreamed! First allow a good period of time for the internal components to discharge before starting. Remove the plastic clip at the base hinge to expose 4 screws - remove all four to release the stand. Then remove the 4 black cross head screws that appear to hold the back on, they do but there is more to do. Carefully tease the silver surround away from the case, best to start in the centre of each side and finish at the corners. There are many plastic clips to release before the surround comes away. Now remove the four cross head screws holding the pushbutton switch circuit board. The whole assembly can now be removed from the case and reveal a metal cover held by 2 SHORT (remember that!) SHORT! threaded machine screws. These once removed will allow the case to be slid away from the holding tabs located down the edges of the cover and removed. Now unplug the connectors from the board that has the mains input connector attached to it. You will see a heatsink with 4 electrolytic caps above it. Silly ACER designers, have placed the capacitors so that they get all the heat from the heatsink! Yes folks, the capacitors are above the heatsink when the monitor is in its normal operating position! So all the convected heat dries them out, nice. So the fault is due to a silly design error! Replace all 4 capacitors, two of them are 1000uF at 16V and the other two are 470uF at 16V, all radial types. Try and get capacitors with the highest operating temperature, at least 105 degree types and remember these are polarised, make sure you connect the capacitor + wire to + on the circuit board. You should have no problems with re-assembly but don't put the wrong screw where the short ones went or you are liable to see it come out of the screen LOL! Most important - - Don't forget the screw holding the earth tag to chassis. Good Luck, you will be amazed how much brighter the screen is now!
Posted on Mar 16, 2007
CompuGuy44
  • 432 Answers
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Posted on Jun 25, 2007
SOURCE: problem in monitor
you need to either buy a new inverter board, or if you are competant with soldering onto boards, you need to replace the c5707 transisters at points q740, q739, q760 and q759 on the larger board. best place really for the replacement c5707s is ebay
Posted on Aug 27, 2007
  • 579 Answers
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Posted on Jan 10, 2008
worldvet
  • 859 Answers
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Posted on Jul 03, 2008
How do i switch it from metric to usa miles and where can i get a manual? My stickers are missing, unknown model serial number or whst year it is.
Hi, Susan could not find anything on the internet but you could take a picture of it and take the picture to a gym or a store that sells exercise equipment and maybe someone can point you in the right direction as far as make and model go. Good luck and have a nice day.
Apr 01, 2016 | Exercise & Fitness
Where does the h35HR exercise bike plug in?
Plug the power adapter into the receptacle on the frame of the exercise bike.
The insert for the power supply should be toward the bottom front of your machine.
If any other issues, please do not hesitate to call us at 888-713-2880 or visit us online at www.sportsmith.net
May 02, 2015 | Exercise & Fitness
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
I have a Fitline r100 stationay bike looks almost new but we don't have a manual and it needs an adapter don't even know where it goes, I hope someone out in this big wide world can help us ou
Hi, I just had the same issue. Look at the recumbent bike from the front (facing the handlebars head-on). The plug is inset into the bike a few inches off the ground on the left side.
Apr 24, 2012 | Cycling
My pedals are squeaking while pedaling on my Schwinn 240 recumbent exercise bike, can I use WD40?
hi.
i cannot see any problems with wd40 on any bike and have used it myself for many years.
just wipe away any excess, and do not spray it on the pedal tops (where your shoes go) as they may get slippery.
light oil (3in1 or simillar) is also excellent on bikes instead of wd40. same advice as above.
i find wd40 works faster, especially on squeaks, but oil works for longer.
i usually use wd40 first to cure the imediate noise, and then use a few drops of the oil to keep it quiet for longer.
hope this helps
Apr 24, 2011 | Cycling
No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
May 20, 2009 | Sport & Outdoor - Others
Battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Apr 02, 2009 | Cycling
Sport & Outdoor - Others Logo
676 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
