Question about HP Office Equipment & Supplies
I have a PSC 1610xi All-In-One printer. It will not move the cartridges when I press print. In other words, it is jambed, not the paper but the part that moves the cartridges. Is there someplace in the area that I can take it to be repaired or possibly repair it myself? I would rather not, as I am not mechanically inclined. I live at 10111 Central, Apt. 223, Kansas City Missouri 64114. My E-mail address is:
  • 3,422 Answers
Please give me the zipcode and i'll will let you know if there are any local repair persons.
I will be waiting for your reply..
Posted on Oct 20, 2008
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
HP 1610xi printer printing very lightly, barely legible, after changing to new HP cartridges and doing cleaning maintenance repeatedly.
Check the settings in your printer driver. I have seen similar issues with a setting often called draft or eco mode. Where it prints very faintly.
May 05, 2011 | HP PSC 1610 All-In-One InkJet Printer
No words print when the printer pulls the paper through
HP support has information that may help: (copy and paste this link into your browser)
Choose the solution that best fits your problem.
Dec 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP psc 1610xi all in one - wont print certain colors
Sounds like your pump station has gone bad. Now with two new cartridges loaded you have flooded the well and it's leaking. Clean up the mess and try using hot water in the plastic tubes to unclog them. If that doesn't work junk it and buy a new printer. It's not worth paying a HP service center to repair it as the cost will probable be more than half of what you paid for it. Sorry.
Nov 19, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610xi all in one printer, scanner, copier. I was in the middle of an important print job, and it said cartridge jammed. I tried taking out the cartridges, and reinserting, didn't help. Tried...
please check where carriage unit is stable........... there have a lock ......... if the lock was broken you will fall in this problem
Please check it ........... if you change the lock part ........... it will be solved
Oct 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
I have a HP PSC 1610xi All in One printer. I
you know what to do is dis, check your key board wether it has be press dawn or the upu had been shake when you are taken it home
Oct 16, 2009 | Office Equipment & Supplies
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Cartridges are stuck, cannot print
Hi all.
I broke the printer and threw it away.
Please consider the problem solved.
Jun 18, 2009 | HP PSC 1315 All-In-One InkJet Printer
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
42 people viewed this question
Ben Johnson
