I have a micromega stage 5 and the disc is jittering in the drive, i.e not spinning any idea's?
Had the same problem I think. When I would load a disc after a few seconds the unit would read no disc. I opened the unit and removed the transport and there is a board under the laser unit, on that board there is an adjustable pot so I plugged the module to the main board and powered the unit up. I adjusted the pot then sat a cd on it until I found a setting that worked. I hope this helps. I am not sure of your ability. Something to remmember is you can only fix it or break it.
Posted on Nov 08, 2008
My WL80t65C has had the RPS replaced, now won't spin the Bowl, does first stage of wash cycle then does not spin the Bowl. Times out. Code 40! Any ideas?
Fisher Paykel Top-Load Washer WL80t65C Error 40
Error Fault Condition
- Spin Basket Will Not Engage Or Disengage From Clutch.
Repair or Check - The spin basket has to be able to rise and fall with the water level. This is to engage and disengage from the clutch. Unplug the washer from power. Remove the spin basket. Remove any objects found between the spin basket and the tub. An object could be interfering with the spin basket clutch engagement. Replace any broken drive components.
Parts for Replacement - Drive Components.
Sep 20, 2016 | Washing Machines
Jitter vertical sync 6 blinks
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 07, 2014 | Televison & Video
Truck keeps dying out. Driving along and it will just die, (Pop start it while still moving and it'll run or sometimes turn the key and it'll fire back up) Dies all the sudden. Replaced the coil. Twice....
check for loose connections/fuse at the key/ ignition switch. Check for loose connection where the ignition gets the power (starter motor terminal)
Oct 12, 2013 | 1991 Ford F250
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
PS3 Blu Ray Drive Not Reading Or Spinning Disc
Check your cables. Try swapping lasers with a friend. Those are the first things I would try.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Why does the disc drive never stop?
it sounds like the motor arm is dirty you will need to take it a dialer or if you can do it your self you will big job on so good luck
Jan 02, 2008 | Microsoft Xbox 360 Console
387 people viewed this question
 Grubhead
Grubhead
