Question about Whirlpool LGR3624JQ Gas Dryer
No heat coming from the dryer
It was working fine and then the next time i went to use it it didnt throw out heat.
cleaned filter and exhaust hose
  • cralspace Oct 21, 2008
    i noticed today that it ammitted a little heat and then stopped
    what info you need?
  • 62 Answers
If no heat, its either a heating element, or if it is gas, the heat coils(need more info)
Posted on Oct 20, 2008
  • cmcarter13 Oct 21, 2008
    The coils will come on interm. for a short period of time, but not long enough to dry clothes
Lavatherm 320 Dryer heats up, but don't dry
Is the Dryer Heating answer yes then have your Dryers Exhaust Cleaned
Sep 16, 2014 | Dryers
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
Originsal problem - dryer would stay on for a half a day on medium heat. Worked fine on regular. Then I cleaned the dryer and vent. I may have possibly tore the vent when cleaning it, but can't find...
Did you also clean the exhaust hose of your dryer, a build of lint in the hose will really hurt the dryers ability to dr your clothes.
A pin hole tear in the dryer vert screen shouldn't have that big effect on the operation of the machine.
Jul 01, 2011 | Dryers
Maytag Neptune Gas Dryer MDG 5500Aww Dryer runs and heats when cold, then after about 5 minutes the flame cuts off, after a few minutews, the ingiter glows red, but the flame does not come on again unless...
Hi!!
I seems like you have a plugged up filter and/or an obstruccion in the exhaust hose/pipe.
Remove and clean lint filter, also remove exhaust hose/pipe from back of dryer and remove any lint accumulated. Check also the exhaust hole in the dryer.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | Dryers
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
My maytag dryer runs and there is some heat ,but clothes take hours to dry
Check dryer exhaust force at outlet. The exhaust should exert strong pressure against your hand. If not clean or replace vent system.
Dryer lint screen may be clogged with lint or finely pulverized detergent residue.
Another possibility is that the operating thermostats may be out of tolerance.
Hope this helps.
Aug 24, 2009 | Dryers
I have a Maytag front load dryer. When you push start everything runs good except the gas won't kick on. I have vacuumed out inside between the walls and drum, removed the lint filter and shoved a...
first make sure gas is on then turn it on and look at the ignighter should be as brite as the sun if so you will here a click when tha gas is to come on and you get nothing then the coils are bad easy fix make sure you unplug it then unplug coils 2 screws that hold it down you can not put them in wrong
Jun 26, 2009 | Maytag Neptune MLE19PN Front Load Stacked...
Dlg 5932w
My suggestion would be to make sure that the lint-filter and the exhaust flex hose are removed and cleaned. If you have the plastic type flex-hose, be aware that these can heat up and catch fire. Be sure to also check the exhaust port coming out of the dryer (that the flex hose attaches to); make sure that there is nothing obstructing the air flow, if there is, then clear & clean and try to restart. If not, I would call a service company...
Jan 12, 2009 | LG DLG5932W Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
