Question about Canon IMAGERUNNER 9070 Copier
Transfer shorting out
Transfer charge is shorting out intermir. across page replaced sep/transfer ***'y still same problem
    Problem Solver:
  • 11 Answers
You may need to replace your tranfer power supply.
-jen
Posted on Oct 30, 2008
I CHANGED THE TONER AND DRUM, WHERE ARE THE MIRRORS AND GLASS ON SHARP 1551-CS
Does this happen when you print!! Not copy. If it does when you print might check the transfer roller and or transfer & sep assemble across from the drum. If printing is OK then clean the glass on/inside the doc feeder you will see it follow the paper thur the doc feeder
Nov 21, 2015 | Sharp AL-1551CS Copier
Unit is printing very light, even after replacing toner with genuine Brother toner. Is possible that I need to replace the drum unit?
Toner sometimes sticks to charge wire which does not allow charge to transfer to drum. Thin wire just thicker than a human hair. To clean carefully scrape from one side to the other with slight pressure with metal tweezers. Wire is 9 inches wide 1/4 inch off of drum.
Jul 04, 2015 | Brother Office Equipment & Supplies
HOW DO I REST AR-M326 SHARP COPIER TO FACTORY SETTING?
lite print might mean the the LASER is blocked (Clean the glass that the LASER comes thru, also the Transfer and sep assy. roller (Sponge looking or the very thin wires across from the drum need to be cleaned or replace (DO NOT WET WITH ANYTHING THE SPONGE LOOKING ROLLER, Replace if dirty
Mar 27, 2015 | Sharp Office Equipment & Supplies
Printer feeds more than one sheet at a time
clean the rollers and replace the sep pad or sep roller which is the bottom roller, first one is pickup top one transfer bottom sep. or replace all
May 20, 2014 | Konica Minolta PagePro 1350W Laser Printer
C0200
Corona wires are used in the transfer/sep assy and drum charge. C0200 is code if they fault. To reset the machine open and close the front door, if ithe code comes back the corona wires and or assy need replacement
Feb 19, 2010 | Konica Minolta DiALTA CF910 Copier
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
ERROR CODE 067
E067 Two or more faults in the primary/ pre (post)-transfer/ transfer/ separation high voltage are detected (including power output stoppage, electric leakage from the primary corona assembly).
Primary and/or transfer/sep unit leaking or arcing.
These are the units that have a very thin wire in them.
Nov 05, 2008 | Canon Office Equipment & Supplies
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
Error c 0210 minolta di 450
Sir,
You mite have a problem with XFER/SEP HV Connection in the first Di450. Also the Housing's on both end of the XFER/SEP assy may need replace ment that would be the two white assy at each end of the XFER/SEP assy. There breaking down due to HV. Also have you replaced the two corna wires in each unit their very fine gold plated wires very thin. They mite have broke or have toner over them clean with alcohol be careful they are very fine wires.
Oct 11, 2007 | Minolta DI-2010F Copier
old marine
old marine
