Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon pixma mp170 error code 5100
Error 5100
  • 5 more comments
  • brideout Oct 23, 2008
    I have a canon PM620 and I am getting error code 5100. I just purchased the printer and installed the cartridges.
  • Anonymous Nov 24, 2008
    same here... i had this problem once (error 5100) shoething was stuck in the printer.. when i removed it it worked perfectly.. but it happend again but this time nothing is stuck.. i turned the printer into 20 pieces and still the same problem.. plz i need help :S
  • shaharsu Dec 19, 2008
    Same thing - one day my MP170 printer showed error 5100, despite having nothing "jammed" inside. It won't print, scan, or do anything, from the computer or from the printer itself. PLEASE HELP!
  • Anonymous Jan 16, 2009
    same, and nothing jamed
  • montyhei Jan 24, 2009
    When trying to print, service error 5100 appears. Says to turn off printer and back on. Does not fix error.
  • Anonymous Feb 26, 2009
    Canon MP170 I get code 5100 and it does not re-set or go away. How to fix?
  • Anonymous Apr 19, 2009
    yeah, my sister and I went to buy new black ink and when i put it in the printer then turned it on it had the error 5100.
    Also when i put the ink in it didn't sound like it was running smoothly i could hear this stutter when the ink thing moves.
  • 4,293 Answers
Hi You can Try
Seen lots of ths errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
4 Suggested Answers
pineworks
  • 4293 Answers
SOURCE: Hi How can I fix error 5100 on my my Canon
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Solution 2:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Apr 25, 2010
Testimonial: "Shaking the printer upside down solved the problem!!! Your are a genius!!! Thank you very much!!!"
  • 153 Answers
SOURCE: error 5100 in canon pixma mp170 however nothing is
you have a purge unit error
Posted on Jun 08, 2009
Beni S-P
  • 1006 Answers
SOURCE: error code MP170
CHECK THIS OUT if it can help:
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Posted on Nov 07, 2007
I've got printer canon PIXMA MP170, it has error 5100. The green light and orange light flashing 2 times flowing each other.
http://www.youtube.com/watch?v=tmTJdJTAhYU
I am assuming this is a new printer install. You have to go thru the entire printer and remove ALL the shipping tapes. This one was worse than my HP all in one, which had 12 pieces.
Mar 03, 2013 | Canon PIXMA MP170 All-In-One InkJet...
Canon erorr 5100
Hi You can Try It may work
Error Code 5100
Solution 1:
Solution 2:
Jan 26, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My canon pixma mp170 says check printer on the screen with error code 5200 and the alarm button is flashing
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Dec 16, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon pixma mp170 all-in-one printer
hi dirkvannoort
have a look here anything in the faqs section
Canon Australia - PIXMA MP170
riz.
Aug 14, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon MP170
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
6,130 people viewed this question
Clive
Clive
old marine
old marine
