Question about Xerox WorkCentre Pro 765 Laser Printer
Please help here:
When I power up the printer it always says "memory error" message. After I hit the stop button, it works just fine. Just wondering what this is trying to tell me. The exact message is as follows: "Memory error. Push stop. Check phonebook." Thanks for the speedy answer.
  • 239 Answers
One way to try to clear this problem is to do a main board initialization.
I believe hold menu + * + # , while turning on the machine.
Hold those buttons,,,,,,, then release the buttons.
If all goes well the machine will come to a ready.
The addresses would need to be re entered, but the copier will work.
Good luck.
Posted on Sep 15, 2011
    President:
  • 2,072 Answers
In all honesty. You most likely have a bad main board. That's the most likely problem with that error.
Posted on Oct 21, 2008
Canon MP560 printer/scan/fax - Does not acknowledge that there is paper in the tray. Will not grab paper. I've tried cleaning the roller, which grabs the paper just fine. I've used this printer maybe 4-6...
If the printer is not working properly or to clear memory try this:
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Or Try This:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon Office Equipment & Supplies
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error message on printer; Waste ink near full
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Memory card error on hp psc 1610
it is a logic card problem.so you can checked it from vendor.
Aug 16, 2009 | Office Equipment & Supplies
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
I can send faxes but I cant recieve any.
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Stupid Canon MP730 waste ink nearly full message
Hello please try this
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
May 26, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Error Message
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Mar 06, 2008 | HP Photosmart 2610 All-In-One InkJet...
My Dell printer doesn,t copy or scan it gives me error 2200
- Turn off the printer first
- Remove the power supply and pressed the power button for 15 seconds
- Clear info out of the printer
- then plug the power back in and press the power button.
Oct 24, 2007 | Dell 962 Photo All-In-One InkJet Printer
Xerox WorkCentre Pro 765 Laser Printer Logo
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
