Question about HP LaserJet 5p Printer
Smeared page When I print a page the paper is tinted with a light grey like dirty rollers. There are areas across the page that are less smeared. I have cleaned the rollers. Do I need a new cartridge or a new printer
    Genius:
  • 1,605 Answers
You need a new toner.
clean the roller again just for fun
Posted on Oct 28, 2008
Print smears on right edge of paper only
It is possible that the fuser film is damaged. The fuser film covers the heating element. Open the back panel, and examine the area where the paper exits. The grey film should cover the same area as the lower black roller. If not, you will either need to replace the fuser or obtain a replacement fuser film and install it. Is the printer noisier than it used to be? The fuser bushings on these printers are notorious for wearing out and causing the film to fail. If the bushings are worn then likely a replacement fuser will be the solution for you.
May 22, 2014 | HP LaserJet P3005n Printer
When documents print out, one side of the copy is smeared. We cleared out a paper jam and I think part of the lining of the roller came off.
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Mar 29, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Hello, when it prints it makes a noise and bottom of page is smeared
Smeared output can result when you re-feed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
As for the noise, there are several complex gear and roller segments that drive the paper between the paper tray, the scanner, the fuser, and the finisher. If these are not perfectly aligned or dirty the printer can make a grinding noise. It's even possible that if the paper is not being fed correctly, that the shift might leave segments of it less accessible to the fuser and prevent the toner from adhering to the page.
But I would try using WD-40 to lubricate some of these components and assume the noise and the smearing are separate issues.
Nov 18, 2009 | HP LaserJet 3330 All-In-One Printer
My HP LJ 4 is printing Grey roller type marks. Not diagonal it's like a rectangle across the the width of the paper about 1 1/2 wide then a space about 1/4 then the Grey again. Any help would be gr
Sounds like dirty rollers or perhaps a bad print cartridge. If you have another ctg to replace try it first if lines are still there check the rollers inside the machine where the paper is fed. Use the sheet to match where the marks are to the rollers on the machine. When you find them clean with alcohol and let dry then try again. there are also paper feed tires that are inside the paper tray that could be dirty also.
Hope this helps
TankMurdock
Apr 24, 2009 | HP Office Equipment & Supplies
Replaced the black Cartridge, however, printing is smearing
The fuser must be dirty. Change the fuser. It is also possible that the rollers along the paper path is dirty, so clean or replace the rollers.
Apr 03, 2009 | Konica Minolta magicolor 2400 Laser...
HOW DO YOU CLEAN A CANON D860 COPIER?
your fuser rollers are dirty and tracking the image
unplug the machine open the fuser area wait until they cool down
take fuser oil(silicone lubricant) and wipe the rollers
while you are at it remove the glass and clean the reverse side and clean the mirror and lens
take a q tip and ubbing alcohol and clean the charger wire
Dec 30, 2008 | Canon ImageRUNNER 1670F Copier
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Lines
I will give you all the reasons I can think of.
1, If the line is only there when running through a document feeder and not there off the glass. The small strip of glass directly under the document feeder is dirty.
2. The drum has a scratch on it, or the cleaning blade is not cleaning the drum properly. Would require that cartridge replacement.
3. The fuser roller may be work in the middle. You would notice some reprinting , or ghost copying if that were bad.
4. Less likely would be some piece of fuzz in the light path, or a small piece of paper or tape in the paper path smearing the ink across the page.
If your machine prints, see if the line is on a print, if its on a print and not on the copy then it is scanner related.
Mar 13, 2008 | Office Equipment & Supplies
Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
Aug 11, 2007 | Kyocera Mita FS 3800 Laser Printer
HP LaserJet 5p Printer Logo
315 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
