My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
    Guru:
  • 859 Answers
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Posted on Oct 20, 2008
  • Glenn Rogers
    Glenn Rogers Oct 21, 2008
    As you can see in the updated fixes in this upgrade, it fixes issues with the Toner Saver feature. This is highly likely the issue you see in your print outs. The printer is trying to save you toner and in doing so is giving you the appearance of faded print outs.
    Once I verify the actual version of the 300 series you have I'll post the update and reiterate the caveats so you don't get stuck with a problem from trying this update. These, needless to say, are normally performed by IT Techs.
    Regards,
    Worldvet
How do I stop bleeding colour on the print-out?
clean the printheads,download utilities to do that if you dont have it
Jun 03, 2015 | Samsung CLP-310 Colour laser printer16ppm...
Why won't my HP 930c print colour when properties set to colour?
Check in printer properties., mught be you selected as print in gray scale or black & white., there select print in color mode..
Apr 29, 2015 | HP DeskJet 930c InkJet Printer
Samsung CLP-310 Colour laser doesn't print properly
This is not a driver or Windows issue, has the ink cartridges been changed recently, it sounds like the the paper is not being magnetically charged before the ink, unplug the power cord for 30 sec plug back in and try printing again
Nov 07, 2013 | Samsung CLP 300 Laser Printer
Error message appears please install supported driver or port
ok So I did alittle research for you.... you either have the wrong driver or your printer is set to the wrong port via the printer properties in windows but here is the driver download page and a manual download as well http://www.samsung.com/ca/consumer/office/printer-multifunction/colour-laser/CLP-310/XAA-support
Oct 10, 2013 | Samsung CLP-310 Series
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
Im having HP Deskjet 6943, I have install black and colour catridge. I print test page its coming ok. But when i try to print colour in MS Word, Excel, Powerpoint i not getting colour, what could be the...
please printer driver setting .. give a print ...select your printer and go to printing preference then go to color tab check for any setting like print in color in gray and print in color ....... select print print in color ......and try ....
Dec 29, 2009 | HP Deskjet 6940 InkJet Printer
Red status light flashing, but none of the toner colours are lit
It means you have to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 16, 2009 | Samsung CLP 300 Laser Printer
Screething noice when turned on and when printing
if its not continuously then its normal
if its not stopping always gives noise then you need to assemble your printers and need to check plastic gears inside the printer unit
MUSTAFA BULENT KILIMCI
YUNUS COMPUTER CEO
COMPUTER EXPERT
e-mail & msn : address mbkilimci@yunuscomputer.com
Sep 15, 2009 | Samsung CLP-315W Laser Color Printer
Colour balance
Original Samsung toners,or 'remanufactured' or home refilled ??
Is the 'background' (ie what should be white) OK ??
Jan 16, 2008 | Samsung CLP-510 Laser Printer
1,217 people viewed this question
jasbo
jasbo
