Question about Infinity 7540A Car Audio Amplifier
No sound when my amp first turns on all three lights blink in a row for maybe a minute. Then the clip light stays on fo another minute. Then the power light stays on but i cannot get any sound. i am trying to run 2 sets of component 6 1/2s off of it. I did everything myself so there is a chance i screwed up somwhere. i ran a 4 wire from the battery to the back with a 100 amp fuse. That goes to my distribution block and i have a 8 wire coming out of there to the amp. the block has a 50 amp fuse. Reason fo all that is future amp. my ground wire is installed under the seat belt in the back with the paint scraped away. I feel i did everything right but apperently not. One more thing i got the amp used but was told functioned 100%. I am hoping i did not get jerked. Pleas help....
    Problem Solver:
  • 11 Answers
I would try it without the slot for the additional amp. However, there is a chance that it is fried. When its powering up I would check the voltages with a multimeter to make sure everything there is in order.
Posted on Jul 02, 2006
SOURCE:
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
Parking, dash lights stay on
sounds like your relay is going out lights stay on for about three minutes then go out is normal but for them to stay on is not .make sure your dash dimmer switch is in correct position also you can before you go in turn lights on then off that will reset timer.
Jan 13, 2014 | 2002 Oldsmobile Silhouette
Sony Trinitron won't turn on, Standby/Timer light now blinks 2x
your power unit maybe going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Televison & Video
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Infinity 7540A Car Audio Amplifier Logo
216 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
