Question about Dell D1028L 17" CRT Monitor
Monitor doesn't turn on when plugged in but when it is plugged out the power LED turns on for few seconds
I have Dell 17" Monitor, Model:D1028L with Chassis No. CM6800. The monitor doesn't turn on (power LED and screen remain black) when power is turned on but when the power cord is plugged out the power LED turns on for few seconds and then goes out. I've technical knowledge about electronic equipments so please help me with this problem even if the solution is technical. Regards, Zahid
  • dear_nitin May 07, 2008
    I have a Dell Monitor (Model No.D1028LR). It has become a nuisance for me for last two and half years. I have spent almost Rs.2000 on it. Its screen used to be blank with LED on Monitor Green. But after switching off and then on one or more times it begin to work well. But now screen flashes for less than a second and then goes blank.
    Can anybody advice me what to do now. Can I get a free service manual for above mentioned model number.
  • gach Mar 02, 2009
    monitor doesn't turn on green LED(monitor always show black screen). some time it show "check signal cable". but I plugged the cable very well.
    I check my VGA ,using another monitor so it work.
SOURCE:
  • 46 Answers
SOURCE: Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Posted on Jun 21, 2008
abhishek0404
  • 81 Answers
SOURCE: Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Posted on Jan 18, 2009
  • 135 Answers
SOURCE: Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Posted on Feb 24, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • 66 Answers
SOURCE: Dell monitor S199WFP....the blue power light stays
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Posted on Jun 18, 2010
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Pc and monitor turn on, monitor goes off after few seconds
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Sep 24, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E207WFP monitor
.Bad news.It cant be fixed.Try to take it back to the shop and get a replacement one.It might work for a few months or so but it is certainly a faulty screen.
Jul 21, 2009 | Dell D1028L 17" CRT Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
How to reset dell monitor d1028l
my monitor screen left said black pls ans me faster
Nov 28, 2008 | Dell D1028L 17" CRT Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Dell D1028L 17" CRT Monitor Logo
91 people viewed this question
Clive
Clive
Alun Cox
