Acer pd726w projector beeps
The projector comes on and so does the lamp, but the lamp shuts off in about 5 seconds and then after 30 seconds the projector beeps 3 times and then a few seconds later it beeps once. The lamp indicator lights red on the unit. Does this mean the bulb is gone? It has had less than 300 hours since new. Please help, thanks.
  • pastor wong Apr 14, 2009
    Did you get the problem fixed? We had the same problem, but the projector worked properly the next day. I checked the manual, the projector made a beeping sound if it detected that the lens cap was closed. But the len cap was not closed. We do not have a clue what's wrong.
  • Manta1969 Jun 30, 2010
    I never found a solution, it seems this model projector has some major issues with bulb life.  The manual says it beeps twice if the lens cover is closed.
Sorry, we did not find a fix, and gave up.
Pastor Wong
Posted on Jan 10, 2010
I hate to echo this problem, but did either of you ever find the solution to beep code? Our church has had the projector for just two years and the lamp must have only about 400 hours on it.
Acer projector blinks then shut off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep
sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Jun 12, 2014 | Acer Office Equipment & Supplies
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Feb 14, 2014 | Acer H5360 3D Video Projector 3D
I have acer PD726W projector and keep shuting down every 15 minute
SOME ONE HAS SET THE TIME IF THERE IS NO SIIGNAL PROJECTOR WILL SHUTDOWN PL SET TO 0
Sep 09, 2010 | Acer PD726W Projector
After replacing the lamp in the projector Toshiba TW300, it shall then appear on the screen saver, and then after a few seconds off. then it beeps and lit LEDs ON and LAMP. How to fix this problem? lamp is...
1. check the lamp and the rating for this unit it may not have the proper rating for the DLP and is shutting down to protect the circuit.
You may not have the right lamp installed.
Feb 09, 2010 | Toshiba TDP-TW300U Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Acer PD726W will not turn on and can't reset
Hook up a playing DVD to the unit via component and try again.
Dec 11, 2008 | Acer PD726W Projector
Acer PD726W
Hi there
You'll have to settle for the ordinary Composite input on the Projector.
You do get a scart to composite convertor from most good PC & AV shops.
Mar 27, 2008 | Acer PD726W Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
625 people viewed this question
jasbo
jasbo
