Question about Mitsubishi CS-26201 TV
No volume When I try to turn the volume up it says that the speaker is off. I have no idea how to tuen it back on or even how it got turned off in the first place. I bought the tv 2nd hand and do not have the original remote.
  • 1,476 Answers
You need to get into the audio menu and turn the speaker on. Usually even without the remote the control the buttons on the set will allow this. Sometimes they are not marked but usually pushing two buttons at once, or holding one while pushing another will work. Experimentation should yield which ones work. Once you are in the menu it should be easy to get to the audio controls using the buttons on the front. Again experimentation and retrys may be required. When you find the correct menu toggle the speaker back on and you should be good. If you don't mind spending the money, and it may make your life easier down the road, this website http://www.remotes.com/ has your factory remote for $67.20 plus shipping. A cheaper alternative may be to buy a universal remote for 5 to 10 dollars but there is no garantee that it will allow you to access the menus. Good luck.
Posted on Jul 12, 2006
  • iluvpurple21 Sep 23, 2011
    I am having the same problem with my TV, I really like the picture I get on my TV so I really would like to fix it. I am gonna try your advice asap hope it works.
SOURCE:
HW701 wireless headphones
Yup. If the headphones are driven by the TV, then turning down the TV turns down the headphones. Check to see if the TV has an audio output setting where you can select either the TV speakers or the headphone jack. What brand and model TV is it?
Oct 31, 2013 | Televison & Video
I have a set of SUN-115H speakers that has a volume problem. When testing with DXDIAG, you can hear the sound but it is very faint even with the volume knob turned to full. Any ideas? ? ?
Is the power to the speakers correct? Since these are computer speakers,have you checked that the volume on the computer is turned up all the way? Have you tried the speakers on another computer or portable radio of something?
May 06, 2011 | Sun -115H Computer Speakers
The ringer is tuened off on my GE cordless phone how do I tuen it back on?
  • Press the "Menu" button on the handset. This button is also the "Star" (*) button.
  • Press the right "Volume" button to browse through the menu. When the display shows "Setup HS," press the "Menu" button again.
  • Press the right "Volume" button until you see "Ring Volume." Press the "Menu" button to enter the ringer menu.
  • Press the left and righ "Volume" button to turn up or down the ringer volume. The default volume level is "L3." Press the "Menu" button to save your change.
  • Oct 17, 2010 | Uniden Cordless Phone
    My mother is has no sound with her computer i think she has inadvertantly turned it off . I'm only familiar with macs i don't know how to advise her to tuen the sound back on
    If her pc has a external speaker, I suggest to check the connections first. If all connections are secured, check the volume. On the lower right corner of the screen (where the clock is), you can find the volume icon there. Click on it. The volume screen will come up, check if it is turned up. If mute box is ticked, uncheck it.
    Now if it still not working, I suggest to reboot. Check again if a sound will come out. If none, check the driver if it is installed. By going to sound speech and audio devises in the Control Panel to check if the driver is there, if not either got to the manufactures website and download it or reinstall the recovery disk.
    Good Luck!
    Aug 02, 2010 | Computers & Internet
    Car speakers crackle even with thw volume all the
    turn the bass all the way down if it still does it your speakers are bad or the deck needs replaced but its more than likley the speakers
    Aug 10, 2009 | Car Audio & Video
    Milwaukee Jobsite Radio 49-24-0200 Ser.-414c Volume Fades
    the volume control needs to be cleaned. if you can carefully take the back off, the volume control may have some small openings in the housing. spray contact cleaner (or even a small amount of wd40) in it and work the control back and forth and see if that does it
    Aug 09, 2009 | GE Superadio III AM/FM
    My speakers shut fown briefly even at small volumes. Help!?!
    are the hooked up correctly positive and negative whats the ohm load of the speakers and amp could be a short in your speaker cables
    could be many different problems
    Jul 02, 2009 | Sherwood RX-4105 Receiver
    BA735nalog
    most probably a connection problem
    Dec 18, 2008 | Boston Acoustics BA735 Computer Speakers
    STR-DE445 Works, but goes into protect when you turn up/down volume
    This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
    Aug 28, 2008 | Sony STR-DE445 Receiver
    Subwoofer volume and sound
    i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
    audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
    manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
    Dec 28, 2007 | Onkyo HT-SR800 System
    Televison & Video Logo
    696 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
