Question about Epson Stylus CX3200 All-In-One InkJet Printer
My epson dx7450 wont work as im missing the inf file
I have tryed to instal my epson dx7450 but it just tells me that the inf file is missing i have tryed to uninstall and then reinstall but this dont work i have surched the web but cant seem to find what i need please help or i think it mite end up out the window
  • taloul72 Oct 29, 2008
    I LOST MY CD ROM SO ICANT INSTALL THE PRINTER ON THE COMPUTER
  • Anonymous Feb 05, 2009
    lost my installer disc for my epson dx 7450
SOURCE: wont print / warning tag wont go away!
yep same problem for me.
Posted on Aug 29, 2008
gwbm
  • 353 Answers
SOURCE: EPSON PRINTERS how to replace inks in epson DX 7450
You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
Posted on Nov 28, 2008
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
57 varieties
  • 1653 Answers
SOURCE: Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Posted on Sep 30, 2009
  • 8 Answers
SOURCE: i accidentally reset my epson dx7450
a-o-yalcin@hotmail.com
I have dx7450 , but havent adjusment to take original binary driver. Send me adjusment than I will send you binary.
saso@anfil.com.mk
Posted on Apr 10, 2010
I accidentally reset my epson dx7450
saso@anfil.com.mk
Mar 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Espon stilus dx7450. doesn't switch on, how can
im trying to install my epson printer scanner have no disc can you help
Dec 31, 2009 | Epson Office Equipment & Supplies
Sep 30, 2009 | Office Equipment & Supplies
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
Vista usb issue no inf file or corrupt
my only suggestion is that Windows Vista doesn't have the drivers for the USB port or it doesn't recognize it's there, I'd try downloading a driver off the internet, install it and see if that works
Hope this helps
Apr 01, 2008 | Computers & Internet
Epson stylus dx7450
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Mar 16, 2008 | Office Equipment & Supplies
Epson GT5500 Flatbed scanner
unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one!
Sorry
Jan 29, 2008 | Epson GT 5500 Flatbed Scanner
Epson Stylus CX3200 All-In-One InkJet Printer Logo
156 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
