Question about Toshiba TP50H50 50" Rear Projection Television
Sound problems Hi, When you first turn the tv on you can barely hear. You have to turn the volume buttom all the way up to maximumin order to hear some sound. About 15 min, later you hear a popping noise and the sound goes back to normal. Please advise. Thank you! Pam
    President:
  • 3,130 Answers
A problem such as this is usually the B+ supply voltage going to the sound IC. It could also be a defective audio processor or audio output IC. These are things that you, as the consumer can't replace, unless you know how to unsolder and solder, and also you have to be aware of the hi voltage inside these sets as well. It shouldnt be a major repair but could run in the range of 150 to 300 bucks depending on what the exact problem is. This number im posting here is for toshiba's service, so they can recommend someone close to you who knows about these sets. Good Luck
Posted on Jul 02, 2006
I can not hear the sound on my Sylvania tv.
is it only with the xbox? how did you hook it up/
Feb 18, 2015 | Sylvania Televison & Video
Low volume on my panosonic
If you are using a cable box or other device upstream, look into it's volume. Typically source units would like to be 30 to to% volume, with the tv or stereo being the final control. What happens is the source volume gets turned too low, and then the final unit (tv or stereo) has to have so much volume to hear anything, distortion and poor sound result. Start with both midway and you should be good to go.
This presumes that you toggled any buttons that said mute or attenuate...
Oct 26, 2011 | Panasonic TCP42C2 42 in TV
HI. i just bought the TV -USED - and the sound does not work. Turned all the way up on the remote and TV. You can barely hear it. Is it worth fixing? thanks Teresa
change the inputs cables on the back of the TV and see if that helps. You will have to go in the menu of the tv and change it to. 1st turn down the volume of the tv.
Oct 13, 2010 | Toshiba 42HDX82 42" Rear Projection...
I cant hear the tv
Hello drive2darim,
OK first check you converter box, Cable TV/ Satellite TV volume control and turn it up to 100%.
Then check the menu on your TV for audio settings and set them to there default settings. This should take care of this issue.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 13, 2009 | Emerson Televison & Video
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Tv rca televison model DZ7649 Entertainment series
  • there is a loose contact in volume control or switch.
  • clean volume control with cleaning chemical & change volume switch.
  • hope this will help.
Oct 12, 2007 | Televison & Video
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
