Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Cant access motor compartment
Model 116.2421590 Found 2 screws to access motor compartment. Other 2 screws seem 2 be hidden under stop/start button. Can't access.
    Problem Solver:
  • 6 Answers
Those screws are hidden under the plastic that you press to make the cord retract.The way I get into that area is to pry it up from the side of the cord retract panel.They take a fair amount of leverage to get it off but it is straightforward from there-Good Luck,
Posted on Oct 26, 2008
  • diane t Nov 04, 2011
    I am trying to get mine off also. Using a screwdriver and prying isn't working. Can't get the clips to release.
I have a kenmore power-mate, 2 motor system vacuum and it's brush wheel is no longer spinning. I was in the middle of vacuuming when it suddenly started making a weaker sound, and I noticed the wheel had...
Depending on which model you have it could be a belt, brushroll and/or motor problem. Some models have hidden tabs that must be released after you have removed the screws to gain access to the brushroll.
Nov 11, 2017 | Kenmore 23612 Progressive PowerMate Bagged...
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Oct 09, 2009 | Riccar Vacuums
How do i disassemble (i.e. which screws do i pull and which hidden tabs are there) the cord retractor/switch assembly? there is only one screw that appears to hold the piece but it does not come out,...
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Sep 26, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Miele solaris turbo plus S514 will not start in live outlet
The reason why the vacuum will not start is because of the cord winder. They are pretty tricky to repair yourself. A service center could probably fix it for about $50.00. It has been a while since I have worked on one of these but I think the screws are under the switch and maybe the filter.
Jan 19, 2009 | Miele Vacuums
Motor filter replacement
If you are talking about the motor cooling filter round filter like this here then you must have removed wrong screws. Screws that you want to remove are hidden under clear lenses on the sides of the unit. You will need a screwdriver to remove the lenses (2 latches at the top of each lens). Once you have removed lenses you will see screws (4 or 6 - depending on the e-series model). Remove them and you will have the access to the filter.
Good Luck
Aug 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
It seems the off/on switch is broken
Sounds like a Hoover, which you had given the model number. But there are 2 or 3 screws to remove the handle, then there are 4 screws in the tool compartment, open the filter door, then the tool comp. should pull out, the switch part # is40309033.
If it is different then this pic, let me know:
Feb 19, 2008 | Vacuums
Problem with motor; need to open the motor compartment
The top piece near the back comes off, use a screw driver to pry the corners out then it will come off. Then you can get to the 2 screws holding the motor housing off. When you put it back on, it just snaps in place.
Oct 24, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
322 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
