WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
WESTINGHOUSE LD-4655VX TV CODE FOR COMCAST XFINITY HD REMOTE
    New Friend:
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Posted on Sep 25, 2016
SOURCE:
SOURCE: comcast remote set up code
Its 10463.
Posted on Nov 22, 2008
SOURCE: I NEED A CODE FOR A COMCAST REMOTE FOR A NEW HCT TV CAN YOU HELP?
press tv on your remote then sutup till it blinks 2 times the press 991 the tv key will blink twice.then press ch+ or ch- till the tv turns off.it will scan all remote codes once your tv turns off then press setup and the the remote will lock the code.
Posted on May 03, 2009
dvinnedge
  • 35 Answers
SOURCE: how to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
Posted on Jul 07, 2009
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Posted on Nov 20, 2009
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
How or where do i get a 5 digit activation code number for my ld 4655vx t.v to hook up to cable
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 13, 2014 | Westinghouse LD-4655VX 46" LED TV...
Ld 4655vx fuse replace
I just fixed this same problem and it wasn't a fuse. I made a video showing how to troubleshoot and fix it.
Sep 28, 2014 | Westinghouse Televison & Video
Get code for Westinghouse model LD-4655VX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 14, 2014 | Televison & Video
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westinghouse LD-4655VX won't turn on - is my power supply broken
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and fix this problem.
Mar 16, 2013 | Westinghouse " 46"" Class - LED - 1080p -...
Tv won't turn on Westinghouse ld 4655vx
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and repair it.
Feb 01, 2013 | MSI Ac Adapter For Westinghouse Ld-4655vx...
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
Jan 30, 2013 | Westinghouse Televison & Video
Televison & Video Logo
571 people viewed this question
Top Televison & Video Experts
Ekse
