Question about Acer Aspire L100 PC Desktop
Won't Power On!
My Acer Aspire L100 will no longer power on. An LED in front does light up when plugged in, but nothing happens when I push the power button. No noises or anything. I have removed the ram, the hard drive and the DVD drive and still it won't make a sound. I wonder if although I have an LED lit up, if the power cord is shot... Otherwise, I have no clue
  • 1 more comment
  • nmgg85 Oct 22, 2008
    I was using a videogame when, suddenly, a blue screen appeared saying there was some error related to "memmory dump" or something like that and that Windows had to be shut down. The screen said that if this was the 1st time this thing happened to me I should restart the CPU, but when I pressed the button to shut it down I couldn't power it on later... Even though I unplugged and unplugged it different times and did different things, it no longer turns on nor makes any kind of noise...
  • Anonymous Nov 02, 2008
    Aside from the overheating and the noise, my L100 also started to turn off by itself until it just died and won't start anymore.
  • Anonymous Dec 02, 2008
    same problem here no power seems like a manufacturers issue
My brother had the same problem with his machine. On doing some research online I came across this site:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390#results
It gave the following 2 solutions to the problem. The first one workedfor a while but then we had to try the second and this seems to havesolved the problem.
Solution 1
ssue
No Power or Will not boot
Solution
If the unit will not turn on and has no power:
  1. Verify that the power cord is plugged both into the unit and an electrical socket.
  2. If it is plugged into a power strip or surge protector verify that the power strip or surge protector is turned on.
  3. Try another power outlet.
  4. Unplugthe power cable from the unit, hold the power button on the unit downfor 30 seconds. Release the power button and plug the power cord backinto the unit. Try to turn it back on.
If the unit has power but does not boot into Windows:
  1. Turn the unit off and unplug the power cord from the unit.
  2. Hold the power button on the unit down for 30 seconds.
  3. Release the power button and plug the power cord back into the unit.
  4. Turn the unit on.
Solution 2
Issue
Recovery media and Restoring a system to factory load
Solution
Acersystems ship with eRecovery Managr, which facilitates the creation ofRecovery media (CDs or DVDs) so the system may be restored to theoriginal load in the event of unrecoverable issues.
How to Make Recovery Media
  1. Click on Start, then All Programs, then Acer Empowering Technology.
  2. Click on Acer eRecovery Management.
  3. If prompted to create a password, create a password and hint.
    Do not lose this password.
    If asked for a password, enter the previously set password.
  4. When the Acer eRecovery Management loads, click the button labeled Burn Disc.
  5. Click Create Factory default disc.
  6. Follow the instructions and put in the required Blank DVD or Blank CD media to make a set of Recovery Media Discs.
How to Recover your system from within Windows
  3. If prompted to create a password, create the password and hint
  4. When the Acer eRecovery Management loads click the button labeled Restore.
  5. Click on Restore system to factory default.
  6. The unit will restart and start the restore.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  7. At the eRecovery Management menu it will ask you how to restore.
    Click on the restore option you would like to use.
How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
We used the recovery from bootup version.
I hope this helps you.
Posted on Nov 26, 2008
How to get a download for a repair manual for A Acer Aspire v5-572p-6446
There may be one available as a block diagramme for a fee on a web site somewhere but that is not common.
Most manufacturer trained computer engineers know how motherboards work alongside the firmware and chosen software so there is no call for them.
Jan 10, 2017 | Acer Computers & Internet
The battery is fully charged, and the ac adapter is plugged into the laptop, when i push the on button the laptop will not start
Remove the battery and power source. Remove the RAM and hdd. Power up with the power supply and it should do something. If it does, replace the RAM and hdd it should now restart. If nothing, check the GPU.
Jan 10, 2017 | Computers & Internet
How do I get the battery out of my acer laptop
Your Model of Aspire has a different battery release method, see attached pic on how to do it. This is a pic from your User Manual, you can download it from here Download Acer Aspire E1 572
Manual
. I suspect that the information you have been given regarding battery removal and passwords refers to removing the cmos battery as in a PC in the hope that it will clear Bios activated passwords.
May 04, 2014 | Computers & Internet
Button keeps blinking
It sounds like it could be either the battery is going bad and not holding a charge or the adapter is. I have had really good luck with similar problems going to places like Batteries +, and large electronic retailers, and my favorite the small local mom and pop computer store; where I end up asking them If I could try one of the adapters from the floor model to eliminate if is a faulty adapter. Other then that I'd if its not out of warranty contact Acers online chat support at http://us.acer.com/ac/en/US/content/service
Jan 19, 2014 | Computers & Internet
HOW TO ENABLE BLUETOOTH IN THIS NOTEPAD ?
The Acer Aspire is a high-performance laptop that includes a fast processor, widescreen display and an internal wireless card. In addition to these premium features, certain models also include one-touch Bluetooth access. If you have an Acer, enabling the Bluetooth is very easy and will only take a few seconds.
1.Turn on your computer and wait for Windows to fully boot. Then log in as an administrator. You will not be able to use Bluetooth under a non-administrator account.
2.Press the button with the Bluetooth symbol on the left side of the computer. This will launch the Bluetooth utility. From here you can sync and manage Bluetooth peripherals.
3.Press the Bluetooth button again to disable Bluetooth. This will disable all connections, but the utility will save your settings so the same devices will sync with the computer again when Bluetooth is re-enabled.
I hope you may find it very helpful.
Aug 25, 2011 | Acer Aspire One PC Notebook
How to turn on bluetooth on acer aspire 5535
According to the manual, "Located beside the keyboard are application buttons. These buttons are called easy-launch buttons. They are: WLAN, Internet, email, Bluetooth, Arcade and
Acer Empowering Technology." Pressing the Bluetooth button should toggle Bluetooth on or off, assuming the correct drivers are installed.
Download the full user manual from Acer here: http://v.gd/eoMupe
Feb 28, 2011 | Acer Aspire 5535-5050 Notebook
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
How do i turn my bluetooth on?acer aspire 5044wlmi
For Acep Aspire 504x model systems that have Bluetooth built in, there is an on/off switch located in the front of the system.
For systems with bluetooth built in there will be two buttons next to each other just left of the mic and headphone ports.
The left of the 2 buttons is the bluetooth switch and the right of the 2 buttons is for 802.11 wireless.
If you only have 1 button then you do not have bluetooth built-in. You can also check to see if bluetooth is included by looking at the bottom, if Bluetooth is installed there will be a white FCC lebel with the name Bluetooth written on it.
Nov 18, 2009 | Computers & Internet
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Acer Aspire L100 PC Desktop Logo
269 people viewed this question
Brian Sullivan
Brian Sullivan
