Question about Jabra BT8010 Wireless Headset
BT 8010 - Charging light won't turn green
I have had my Jabra BT8010 for about 1 year and never had a problem charging it. Today, I plugged it in and the red charging light is flickering. It normally takes a couple hours to fully charge, but it has been charging for about 3 hours now and the red light is still flickering. It was not totally dead when I starting charging it, so I don't know if it is charging at all because it does turn on when I unplug it from the charger. I do not remember the red charging light flickering during charging, and am wondering if it normally flickers when it's charging or maybe something is wrong. Thanks.
SOURCE: Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Posted on Aug 20, 2008
SOURCE: Pairing Jabra bt8010 with a Vista Computer?
What you can do is go to dell's website and dl the bluetooth driver
I read it online
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central
Just go ahead and dl the bluetooth driver at the "network" tabs.
Posted on Aug 21, 2008
  • 3 Answers
SOURCE: Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Posted on Oct 27, 2008
SOURCE: make jabra bt 150 discoverable
within connections settings on your phone your jabra will always be discivered if you have set your bluetooth within phone to be on all the time, when you switch on head set it will be automatically picked up by your phone.hope this helps
Posted on Mar 07, 2009
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
Jabra bt530 does not hold charge
Did it used the charge before?
How long do you have it for?
How often is it required that you change your battery?
Is your charger really connected to the power socket?
Does it show a charging light?
Feb 11, 2014 | Jabra BT530 Bt HDst Black Bluetooth...
AKG K 830 BT
Possibly the transmitter is not working or it needs pairing again.
Jun 23, 2017 | AKG K830 BT Bluetooth Headset
Can't find anywhere the bt8010 software
Bluetooth headset hbh-iv840 sony ericsson doesn't work with my ipone4s to lisen to music, can someone help?, plssssssss :)
Feb 05, 2013 | Jabra BT8010 Wireless Headset
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Radio Communications
Jabra BT 5010
I have the same exact problem... I went to the shop and replaced it and again the new one doesn't charge. F***** jabra did anyone tried to call the jabra support about this ?
May 09, 2008 | Radio Communications
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Sep 28, 2007 | Jabra BT250 Consumer Headset
Jabra BT8010 Wireless Headset Logo
124 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
