Question about Bose 3·2·1 II System
WHY CAN'T I GET AM RADIO RECEPTION - ONLY FM??
I RECEIVE FM RECEPTION BUT NOT AM
ANY SUGGESTIONS??
  • MickyPearl1 Jan 09, 2009
    Just moved to a new house on the outskirts of our city. We can received FM radio signal anytime, but most of the time the AM stations are obscured by static. MOST of the time that is. Once or twice weekly AM comes in clearly...not on the same days or times each week, and not under the same weather conditions. There are also some cow pastures nearby which contain some humongous towers. Don't know if they are radio, TV, electric power or what, but that's my next best guess. Something whose operation blocks my reception. What can I do about this? Are there separate AM antennas which can overcome this problem?
You need a seperate AM antena for your AM radio to work. If you look on the back of the system where the FM antenna is connected you will see a AM hole for an antenna. I had same problem hope it helps!
Posted on Nov 08, 2008
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Aug 07, 2014 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
1993 silverado no FM reception
That has been a problem with them for years allready that the FM Screws up on some of them, Just go out to a auto wrecker end get a different radio for it,It will cost you less , Then to have it repaired,
Dec 02, 2012 | Ac Delco AM-FM Radio Cassette
Cannot receive AM on radio
I really hate to say it, but AM reception has been a problem for over 50 years....that's why FM was invented....
Anyway, if the FM stations are coming in and none of the AM stations are working, the problem has to be inside the radio unit itself.
Dec 03, 2011 | 2006 Volvo C70
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
FM RADIO Reception
No, it should work, although it will depend on how good your reception is. This depends on how strong the signal is where you are trying to receive. If you have tried scanning for channels and all you receive is static, it's possible your tuner is bad. Have you tried to tune it to a known good station manusally?
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
Excessive static on AM stations. Waves in and out. Not so on car radio. Is there an antenna to eliminate this?
Turn on the radio and turn the AM/SW BAND switch to the AM position. MW appears in the display. Use the outer ‘fast’ tuning knob to find stations, fine tuning with the inner ‘slow’ knob
when needed.
• If there is interference from adjacent stations, place the BAND WIDTH control in the NARROW position. If there is no interference, leave it in the WIDE position.
• If there is excess background noise, turn on
the SW LPF switch, which may minimize the noise.
• If a station is so strong that audio distortion occurs, reduce the gain level with the AM/SW RF GAIN control knob by turning it counterclockwise.
• The telescopic antenna does not have to be extended for AM reception. The radio has an internal, directional, ferrite-bar antenna for AM reception.
• To optimize AM reception, swivel the radio until maximum signal strength is achieved.
All of that being said: It's very tough nowadays to receive AM in this 2008 electronic world. If your able install a longwire SW antenna outside, and have access to a good earth ground, you can boost the AM signals and beat the noise being generated all around you.
Jan 08, 2008 | Grundig S350 AM/FM/SW Radio
Bose 3·2·1 II System Logo
1,504 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
