Question about Lexmark Z1420 Printer
Lexmark 1190 problem
I can't print anything from my laptop because there is a previously printed
document still in the print queue that blocks any other documents that I
want to print.I've tried the cancel document option but it is still stuck with
"deleting" next to it. Any ideas please
Davey h
This has happened to me before and i just unplugged the printer and restarted the computer
Posted on Jan 25, 2009
Lexmark interact S605 has document blocking any further printing and even when I have unblocked previously the next document still blocks
If you're having problem with print jobs getting stuck in the print queue, it could be due to your computer's print spooler service not running. Try the steps below to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark Interact S605 All-in-One Color...
Printing blocked by a document showing being deleted
Sounds like a stuck document is in the print queue. Try to clear the print queue first before sending another print job otherwise it will just accumulate in the queue. The steps below will help you clear the queue.
Feb 21, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Printer wont print. help!!
Hi albookristin
I believe evrytime you tried to print, they all lined up in a queue for printing. If that is the case, you have to delete everything in the queue
Right click on the printer folder, look under documents, and see there are documents listed. If there are few, delete all of them. In some cases, you may have to print one at a time.
After doing all that, try to print a document. For test purposes type a one line document and try to print it.
Hope this will work for you.
Have a good day
luciana44
Nov 15, 2009 | Lexmark X2500 All-In-One Printer
I have a pdf document to print and it doesn't print it, and in the window box for the printer it says that 1 document is in queue (which I don't understand what queue means) and if I try to cancel the...
How large (how many pages) is the PDF document?
Try printing only the first page.
Then try only 5 pages at a time.
The queue is the disk area where the document (in print-out form) is held until the printer can service it (print it). This is known as "background printing".
Oct 07, 2009 | HP DeskJet F380 All-In-One Printer
DOCUMENTS FOR PRINTING DON'T GO INTO A PRINT QUEUE
If you mean that when you go to print a document it doesn't hang in the Windows print queue and leaves quickly, then it is because either the printer has grabbed the document into its memory or it has sent the document to what it thinks it another printer. It might also be that the drivers you are using are not set correctly or that the connection to the printer is incorrect.
Jul 09, 2009 | Lexmark E232 Laser Printer
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
Jun 07, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
I have a Lexmark 5490 connected to a D-Link DPR-1260. The D-Link configuration utility installs the printer on my Vista Home Premium laptop as the default printer and recognizes that the printer is...
Check your windows firewall or your antivirus.
Disconnect that for a while and delete all pending documents (queue).
Send a new doc to print and see what happen.
Usually those program are blocking the communication between printer and computer.
If this is your case, set a rule on your antivirus program.
Have a great day!
Pablo :-)
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Lexmark Z1420 Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
