DVD IS FROZEN ONLY SAYS HELLO HELLO - Televison & Video
  • 2 more comments
  • SDSLEE Oct 20, 2008
    RCD DVD RECORDER
    RCA DVD RECORDER AND PLAYER IS FROZEN AND
    ONLY SAYS HELLO HELLO REMOTE WILL NOT WORK ON IT
    RCA IS FROZEN AND THERE IS NO DISC STUCK INSIDE
    I HAVE UNPLUGGED THE DVD REWRITABLE RCA DVD RECORDER AND PLAYER AND THERE
    IS NOT DISC IN THE UNIT. THE UNIT ONLY SAYS HELLO AND HELLO AND WILL NOT RESPOND TO THE REMOTE
    Brigadier General:
  • 6,966 Answers
The "H E L L O" message is part of the booting/initialization process of the built-in micro processor of the RCA DVD Recorder. Just like in a PC, it can also suffer from crashes/hangs. If you are considering a repair, probable areas to start checking would be:
  • firmware, might need a re-flash or update;
  • hard drive, might have bad sectors or require replacement.
Alternately, if you are not considering a DIY (do-it-yourself), you may have to re-evaluate the options since in some instances, cost and time of repair may no longer justify having the unit serviced.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 20, 2008
    Genius:
  • 3,422 Answers
Please reset the unit by unpluging all the cords of the player for 30min even the power cord and then plug it back in.Now turn it on and let me know if you still get the error.
  • 928 Answers
Can you provide the brand and model number of your DVD player?
In the meantime try unplugging the unit for about 10 mins then plug it back in and see if the same problem occurs.
  • 19,396 Answers
Unplug the power cord for five minutes, check if there is a disk stuck inside.
  • 2 more comments
  • Ginko
    Ginko Oct 20, 2008
    Start unplugging the power cord, wait five or ten minutes, and plug it back.
    If that does not work, then check if there is a disk stuck inside, if there is a disk inside try pushing repeatedly the eject button while you turn the unit on. do this a couple of times until the disk ejects.
  • Ginko
    Ginko Oct 20, 2008
    If ther is not disk stuck inside you perform a factory reset by unplugging power, and plugging back power while holding down the on button on the recorder, hold down the button for ten seconds or so until you see the unit restart.
    If it does not restart the firmware is defective, otherwise , or it just does not work, or you get error message.
    I will see if there is a factory service menu that can be accessed using the remote, if there is none, or the unit does not respond, then the only thing to do is using an image CD to restore the firmware/software. The CD is only made available by the factory to authorized repairers.
  • Ginko
    Ginko Oct 20, 2008
    I forgot to mention, you need to give me the complete model to get more help.
  • Ginko
    Ginko Oct 20, 2008
    Here is the reset procedure using the remote:
    "disconnect it from all power and cable sources, leave off for 1/2 hour,
    then plug back in and hold the stand by buttons for the remote and on
    the machine at the same time"
    From I have a RCA DVD Recorder
Awa tv frozen how do i fix this ???
Hello killerhooter,
Just unplug the power cord to the tv. If the tv is frozen from the dvd player or from a cable box, then just turn those off or unplug the power supply as well. Only need to be unplugged for a few seconds and then plug it back in. Good luck.
-Joe
Aug 29, 2011 | Televison & Video
The mouse or arrow of my pc stops and i have to restart my pc again.
Confirm if your PC is frozen, or if the mouse has stopped working by pressing the WINDOWS key on your keyboard. If the mouse has frozen, pressing the windows key will bring up the start menu. If it does not open, then the Operating system is frozen. Try opening your DVD / CD-ROM device. When it opens, the PC is not frozen.
If the Operating system is frozen, then most likely you have a Hard Drive problem, extreme Hard Drive fragmentation or corrupt system files causing this.
May 30, 2010 | Acer Computers & Internet
Dvdr is frozen at hello mode;it won't open nor start up. I've tried to reset but nothing happens. Any recommendations
Try this...I'm not 100% sure if it will fix it, but it's worth a try. Get a paper clip and straighten it out. Now poke one end of it in the little tiny hole on the front drawer of the DVD player. This will release the drawer mechanism so that it can open. You may have to open it by hand....
Feb 23, 2010 | Televison & Video
Partly Frozen DVD player that is unresponsive
HELLO
OK! try plugging the unit back in to the mains power and bring it out of standby (if you can) and press eject. If nothing happens - don't panic!
Unplug it from the power and remove the lid off the machine. Where the disc is you will see what is called the disc clamp (this bit holds the disc in place when playing).
it's made of plastic and there should be TWO visible screws (one at each side) they may have black rubber stoppers over them. Take off the stoppers and remove the screws and the disc clamp will just simply lift off and it's very easy to replace as well.
There may even be a place on the bottom of the unit where you can insert a hair clip or something to release the mechanism.
Hope this has gone some way to help you (:-)
Oct 05, 2009 | Cyberhome CH-DVD 300 DVD Player
System stuck on "hello"
I had this same problem and held down the play button after unplugging the player. What i found was that i could boot up, but that shortly after the screen would scramble and alternate between static images and a green screen that flickers. I believe the single chip that drives this has failed.
Dec 23, 2008 | RCA DRC-285 DVD Player
Says "hello" then does nothing and says "stop"
try tv on video 1 or 2 or 3 or AV or hit the set up button tv to get to right place
Sep 25, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
