Question about Microsoft Windows XP Professional
How to find remove xp antispyware 2009
I got this ptoblem this morning and cant solve it i have on the lower right side two icons one is a shield with red green coloring in it the other is a circil with a + in it they tell me that i have a spy war virus
please help
    Guru:
  • 57 Answers
You can clean it. Download the trial version of malwarebytes antispyware. Then run a quick scan. If that doesn't clean it, do this also:
  • run smitfraudfix: choose the search option, after it's done, reboot in safe mode, and run it again but choose the clean option
  • run vundofix, and clean anything it finds
  • Optionally, run spybot or ad-aware to clean up any traces
Posted on Oct 21, 2008
  • Microsoft Master
  • 1,183 Answers
To be very true, there is no permanent fix to the problem, except for reinstalling the windows after a complete format. This is very annoying virus. You can get rid of it by deleting, the enteries in the registery , but it tends to return and the only fix that i was able to find was to reinstall , coz thats exactly what i ended up doing on my computer. As i had the same problem
Thanks
Proton
Posted on Oct 20, 2008
On windows vista some desktop icons have a security shield on right side of icon. how do you remove shield and not lose the security?
The icons having Shield icon associated with it means that they need administrator privileges every time they run. Not any kind of security as you think, this thing simply says that they should be run from any administrator's account or other account with administrator password.
Hope this helps, Mrityunjay.
Jun 20, 2012 | Microsoft Windows Vista Home Premium...
Tip
How to disable/enable email scanning in Trend Micro AntiVirus plus AntiSpyware
1.Open the Trend Micro AntiVirus plus AntiSpyware main console by doing any of the following:
Click Start > Programs or All Programs > Trend Micro AntiVirus plus AntiSpyware > Trend Micro AntiVirus plus AntiSpyware.
Double-click the Trend Micro AntiVirus plus AntiSpyware icon on the lower right corner of your screen.
2.On the left panel, click Virus & Spyware Controls. Under Protection Against Viruses & Spywaresection, click Settings.
3.Under Check for the following threats section, put a checkmark in the checkboxes for Threats in incoming mail and Threats in outgoing mail to enable mail scanning. To disable it, remove the checkmarks.
4.Click OK to save your settings.
5.Close the Trend Micro AntiVirus plus AntiSpyware main console.
on Mar 07, 2010 | Trend Micro Antivirus + Antispyware 2009...
Jun 20, 2012 | Microsoft Windows Vista Home Basic Edition
Cant find the alternator in my 2002 lincoln ls
3.0L lower front of engine passenger side above splash panel. 3.9L top front of engine under engine cover
Jan 21, 2011 | 2002 Lincoln LS
Updates not installed on computer
Please go to add/remove from setting in control panel.See whether the application is listed over ther.If you don't want that application any more, remove it from there.
Aug 08, 2009 | Computers & Internet
How to 1998 Taurus altenator R&R
please rate highly if this helps
Generator 3.0L (2V)
Removal
  1. Partially raise the vehicle on a hoist. Refer to Section 00-02 .
  2. Remove the right front wheel. Refer to Section 00-02 .
  3. Remove the lower fender splash shield retainers and position the shield out of the way.
  4. Lower the vehicle.
  5. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  6. Remove the power steering line bracket and heater hose support bracket from the generator.
  7. Remove the upper generator bolts.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Disconnect the right hand stabilizer link.
  15. Lower the subframe to provide clearance.
  16. Remove the generator.
Installation
  1. NOTE: Do not tighten the lower bolt.
    Install the generator and the lower bolt.
  1. Raise the subframe and install the subframe bolts. Tighten the bolts to 90 Nm (66 lb-ft).
  1. Connect the right hand stabilizer link and torque to 47-62 Nm (35-46 lb-ft).
  1. Remove the adjustable stand.
  1. Lower the vehicle.
  1. Install the upper generator bolts and tighten them to 25 Nm (18 lb-ft).
  1. Install the power steering line bracket and the heater hose support bracket. Tighten the nut to 20 Nm (15 lb-ft).
  1. Install the accessory drive belt. Refer to Section 03-05 .
  1. Partially raise the vehicle.
  1. Tighten the lower generator bolt to 25 Nm (18 lb-ft).
  1. Connect the generator electrical connector.
  1. Install the battery positive B + cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Install the generator splash shield.
  1. Install the fender splash shield and the retainers.
  1. Install the right front wheel.
3.0L (4V)
Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 14-01 .
  1. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  1. Remove the power steering line bracket and heater hose support bracket from the generator.
  1. Remove the upper generator bolts.
  1. Remove the right front wheel. Refer to Section 00-02 .
  1. Remove the lower fender splash shield retainers and position the shield out of the way.
  1. Remove the generator splash shield.
  1. Raise the vehicle.
  1. Disconnect the electrical connector and remove the battery positive cable from the generator.
  1. Remove the right subframe bolts.
  1. Remove the lower generator bolt.
  1. Lower the subframe to provide clearance.
  1. Remove the generator.
Installation
  1. Install the battery positive B+ cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Connect the negative battery cable.
3.4L (4V)
Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the right side cowl vent screen. Refer to Section 01-02 .
  1. Raise the vehicle and remove right front wheel assembly. Refer to Section 00-02 .
  1. Remove right tie-rod. Refer to Section 11-02 .
  1. Remove accessory drive belt (8620) from generator. Refer to Section 03-05 .
  1. Disconnect electrical harness connector and output terminal wiring.
  1. Remove nut and position engine control sensor wiring (12A581) out of the way.
  1. Remove the two bolts and one stud bolt.
  1. Remove generator from vehcile
May 12, 2009 | 1998 Ford Taurus
MS AntiSpyware 2009 alert appears on my screen and as Icons/These have been identified by Norton 360 as a virus. How do remove?
Download Malwarebytes. Install it and run a full scan:
http://www.filehippo.com/download_malwarebytes_anti_malware/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 05, 2009 | HP Pavilion dv9000z Notebook
How can I get rid of CA parental control? I never set it up!
AntiSpyware 2008 is a rogue anti-spyware program from the developers as Antivirus 2009. This program is advertised through misleading and deceptive web sites that pretend to be malware scanners that find infections on your computer They do this to scare you into thinking your infected, even though a web site can't possibly know this, in the hopes that you will download and install the AntiSpyware 2008 program. If you decide to install it, the program will scan your computer and come back with a list of security risks found on your computer that you cannot remove unless you first purchase a license of the software. It is important to remember that these people are preying on your fear and for the most part you do not have the infection they say you do.
Antispyware 2008 Automatic removal http://www.2-spyware.com/spyware-doctor.exe
Antispyware 2008 XP manual removal: Kill processes:
  1. application data
  2. secure solutions
  3. antispyware 2008 xp
  4. as2008xp.exe
  5. as2008xp.exe
  6. %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe as2008xp.exe setup_100527_3_.exe %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe setup_100527_3_.exe
Click start,Run,Type REGEDIT,click ok.
Go to the following keys and delete.
Delete registry values:
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lgid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp pid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 installtime
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 start counter
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1\config
Please rate this a fixya
Feb 11, 2009 | Computer Associates Anti-Virus Plus...
I have a new laptop which has built in wireless but I cant get it to connect to my house internet. I entered a wrong passcode and now cannot work out how to reset it so i can start again
Vista or XP? XP is the easiest. Click on the Wireless icon in the lower right. click on advance settings>wireless networks and remove all the preferred networks or just the one you wanted to sign in to in that box. VIOLA! start again.
VISTA a little harder. right click on the wireless icon. click networks and settings. in the left side bar click manage networks. Find your network device and right click properties. Security tab to change the password settings.
Sep 04, 2008 | Computers & Internet
MY GATEWAY LAPTOP "MX6214" IS GETTING A MESSAGE ON BOTTOM RIGHT CORNER SAYING THE SYSTEM IS DETECTING ACTIVE SPYWARE. WHEN I CLICK ON THE MESSAGE, IT DIRESCTS ME TO A "VIRUS-HEAT" ADD...
It is a virus or spyware try running a antivirus or antispyware prog if that doesn't help you will have a choice live with it(easy, but annoying), take it in (easy,but expensive), or save all your important files and reload everything (little more difficult, but cheap). Hope that helps you out. Either way you do it make sure to always have antivirus and antispyware running, you can get good ones for free. here are some links.
antispyware
http://www.microsoft.com/athome/security/spyware/software/default.mspx
antivirus
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?tag=pop.software&cdlPid=10834624
Jun 08, 2008 | Gateway Computers & Internet
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
