Question about Toshiba 46HM95 46" HDTV
Sound but no picture in PIP
When I switch to PIP mode I get sound but not picture from ANT1 and Ant2. Video selections work fine in PIP. It just started this after 2 months.
  • 1,476 Answers
You mention that the unit is 2 months old. It should be under warranty and should be covered by the store you purchased it from or the manufacturer. If you or any unauthorized person works on it you will void the warranty and besides that's what you paid for when you bought it. Have it looked at by the appropriate warranty person or facility.
Posted on Jul 12, 2006
Tv/video switch won't switch
The model indicated is a older Toshiba rear projection(if another brand/model let me know)
You should be able to select the rear inputs either via the remote (original one) or with the input (video) button on the set.
If in the menu they are grayed out--it means they have been locked out.
Failing that a serious problem exists in the set's microprocessor.
Hint: if you have not tried it UNPLUG THE SET FOR A WHILE TO SEE IF WHEN YOU PLUG IT BACK IT WILL RESET and restore the inputs.
Mar 23, 2012 | Toshiba 42H81 42" Rear Projection...
PIP fuzzes out, then snaps back in
It is definitely a circuit problem tf
it could be the pip board and or
components on or around it.would
require technical knowledge to
repair
Nov 30, 2007 | Sony KP-57HW40 57" Rear Projection...
Just got an antenna to pick up local HDTV channels. I scan the channels and none are found. does it matter if I connect to "Ant1" or "Ant2"? neither seem to work. Thanks.
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
Feb 06, 2010 | Toshiba 56HM66 56" Projection HDTV
PIP problems Philips model 42PF9631D/37.
if you have a cable box and run it thour the cable box it will not work. cable befor the cable box you can do it put a spirer on the line be for the box run one to cable box 2 to the tv ant1 ant2 that is the way you can do it.
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
How to set up cable input on television...searching for channels
the wd52525 has 2 antenna inputs. put the cable in the bottom one first (ant1) press menu, then scroll over to antenna, the scroll to ant1 and hit enter. if none are found repeat using ant2. if none are still found then the chassis is bad or you have no signal. try the cable on another set if it works then visit www.tv-tech.com
Dec 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
How do I set up the picture in picture function on my tv
there should be two antennas connections in the back ant1 and ant2 connect both up to cable and click pip on the remote
Jan 23, 2008 | Hitachi 57F500 57" Rear Projection...
55 inch phillps projection tv model #55p8341
you have to have your ant/cable connected to but tunners on the back you should see a ant1 and a ant2 then select pip from your remote
Jan 20, 2008 | Philips 50P8341 50" Rear Projection...
Need to ask how to Repair my TV.
Check F801 for open and if open replace with 6.3a 250v slo-blo...
If open and replacement slo-blo opens immediately suspect audio Ic2301 Part Number # An5277. Ic shorts and drags down 30v line stressing main fuse.
Always replace C832 using a 35v 220mf. (original is16v/220mf).
Also, another possibility could be the deguass thermistor D808 P/n# D4ddf1r50001 but try the above first.
Bill
Dec 15, 2007 | Panasonic CT-36SX31 36" TV
Shadow box/signal block?
Check the closed caption settings. To me that looks like the TEXT mode is turned on.
Feb 19, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
Toshiba 46HM95 46" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
