I charged it for more than twelve hours, yet it refuses to come on.
SOURCE: GPX MP3 Player MW3837 does not turn on
Not sure but I had same problem if you turn off the hold button on the left hand side and hold down the play button it should turn on.
SOURCE: my gpx MW 3837 mp3 wont turn on
I bought one for my brother, and I had the same problem, but after i had plugged it into the computer and downloaded a song onto it, it turned on just fine.
SOURCE: battery wont charge
I would say leave it stay on then after its fully dead charge it up again . That should fix your problem if it doesn't leave a comment and ill try to help again.
SOURCE: My GPX ML648S MP3 player turned off while charging
are you charging with your computer through the USB cord or did you get an adapter to charge via an outlet?
If charging with your computer, it could be a bad USB port, try the ports in the back of the tower if your using the front and vice versa.
Is the device responsive otherwise? Can you load music and the like while the device is connected? If not your USB Cord could be faulty and need to be replaced.
If you are using a laptop keep in mind that sometimes the amount of voltage required for this device does not always reach the USB ports. Try disengaging the laptop battery for an hour and then reconnecting it.
SOURCE: MP3 Player Not Charging, Not Turning On
Do a a hard reset if the mp3 player isn't charging.
How to do this?
1)Near to the USB port u will find a tiny hole below which "Reset" will be mentioned.Insert a small pin into that hole and walla"Hard Reset".
I suffered from the same problem and after doing this , my GoGear started working.So all the very best!!!
