Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Round yellow glow
Have a Zenith M52W56LDC. There is a round yellowish glow towards the center of the tv. Is especially evident on black and white movies, but also shows up in color, casting a yellow glow that fades towards the edges of a 6 in or so diameter circle. Have had the tv for 14 months, and nine months ago the ballast and lamp were replaced. Any ideas?
  • 1 more comment
  • miaatch Feb 18, 2009
    I have a yellow glow in the center of my tv. i just bought this tv from a really good friend of mine and he said it was fine when he had it and after i plugged it in at my house i noticed it. the tv is about 3 years old now. could this have happened during the move or maybe he just didnt notice it or just coincindence? how do i fix it. im fairly handy and like fixing things myself if not to complicated. how do i fix it? what do i need to order? and any advice?
  • rich Mar 15, 2009
    i have the same yellow glow problem but with blue dots around circle
  • miaatch May 11, 2010
    i just posted my issue im having with my zenith M52W56LCD and a large yellow spot in the middle. i just wanted to post my email address in case someone could help
    Miaatch@aol.com
    Mitch
Your problem is caused by a pre polarising filter becoming discoloured with heat. I am sure zenith supply a replacement filter for about $50 US which is more than can be said for LG. I have been searching in vain to find an article which refers to part numbers for the filter. If you do find a part number for it please post it on the forum so other people all over the world with the same fault can obtain it. I have stripped down the light engine on many of these sets and believe me it is not that difficult, just time consuming
Posted on Jul 27, 2007
    President:
  • 3,130 Answers
I would have the lamp and ballist checked again, as thats about the only thing I know that has ever caused this complaint. Sorry I couldnt be of more assistance. Good Luck
Posted on Jul 02, 2006
SOURCE:
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Oven doesnt come on most likely its the ignitor but i dont have a meter to ohm it out and dont know the sequence of operation like a furnace cause usually if u have that u know what steps to take to...
Hi, if you don't have an ohms meter the best way to check is fire up the boiler if it works then the problem most likely is with the ig niter. Either the ig-niter will glow or it wont. If it does not glow check it for a crack or evidence of damage. You should see scorching a crack or just basically broken. If it glows check to see what color it glows. Uneven yellowish/orange? it's bad replace it. Even bright yellow to the point where you can't look at it? It may be good. Mike
Dec 02, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Just trying to hook up a new DVD player to my 1998 Zenith TV?
Connect your video source [cable, satellite, etc] to your dvd and connect your dvd to your tv. Get back if you still have a problem.
Jun 19, 2009 | Zenith A25A23W 25" TV
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Yellowish green problem
could be picture tube or deguassing coil. Remove any magnets around set including speakers etc. Try turning off and on see if makes a different.
Sep 21, 2007 | Zenith D52WLCD 52" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
