Question about Whirlpool LSR5132PQ Top Load Washer
Washer overfilling washer is overfilling
  • William Weekes Jul 02, 2006
    could i be given a solution for this problem
  • 641 Answers
There are two reasons could cause washer's overfilling. - A defective water entrance valve - Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. - Water switch level - I am not familiar with this specific machine, but there are 2 types of level switches. 1)A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. 2)Floating switch that located inside the dishwasher's bottom and operate a switch. In case there is a floating switch in your dishwasher - check for its smooth movment and check as well the switch by a multi-meter (an on/off switch). Defective switch should be replaced. If level switch in your dishwasher is a diaphragm device - Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Posted on Jul 02, 2006
  • Dov Dror Jul 02, 2006
    All places I mentioned dishwasher = washing machine.
    Water switch level - Apply to the diaphragm devie only.
    Sory for the inconvenience.
    Good luck !!
Responding to Dovi's post - I have a Kenmore series 70 Washing macine (circa 2005). I was having this tub-overflow problem. At first I thought it was the diaphram, but later (thanks to your post) I realized it was the Water entrance valve.
Two things I'd like to add here:
1. On my machine, the ability to take the valve apart and clean it, didn't seem apparent. I like to think of myself a mechanically inclined, but I still didn't see a way. It looked like a sealed unit - and that may just be the way it is on my machine.
2. But, a trouble-shooting tip I can offer here to anyone else with this problem is this:
a.) Dovi's post what made sense to me was that this valve (in this case the cold water entrance) should only be open it has power. So, when the machine was unplugged and the feed hoses disconnected. I blew int the inlet - no resistance. Ah ha!
b.) To confirm, I blew on the Hot-water entrance valve - complete resistance. So, that told me the coldwater entrance valve was stuck open.
c.) since I could find a easy way to dissasemble the unit, I just lightly tapped on it with a screw driver a few times to unstick the valve. Then blew on it again. Repeated process until I had complete resistance.
Lastly, if it does this again - I'll just order another valve.
Thanks for the post Dovi. Very, very helpful.
- Steve
Posted on Feb 09, 2008
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
Hi. My Whirlpool Duet Sport washer stopped mid-cycle and is flashing F-. I can't open the door. Help!
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Mar 21, 2011 | Whirlpool Washing Machines
What is the lf code on the cabrio washer?
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Mar 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer will flash the code FL what dose this mean??? thanks for the help model 21062
fl flashes if any overfill condition occurs.this condition occurs when excessive water in the tub causes the overfill switch to trip.the control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for fl to be displayed.with an overfill condition ,the beeper repeats a warning every 10 seconds with no time-out.the pump is cycled in drain mode for 30 seconds on 30 seconds off untill the overfill switch resets or power is discontinued to the unit.press stop/cancel to clear the display.
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
FL alert
Sep 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does FL mean when it comes on washer ?
Flood condition "FL"
***If there was not an Overfill condition and, the SUDs were not present when this alarm was initiated, thsi will confirm a faulty Overfill switch and, it should be replaced.
Jul 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
1,956 people viewed this question
Sal De
Marvin
Marvin
jimorris77
