Pentax Optio S50 Digital Camera
Problem for Pentax Optio S50 Digital Camera
Will not power on, lens stuck, poor warranty
By deedee on Jul 02, 2006
After taking about twenty pics with a new Optio S50 camera, the lens would not extend and the camera would immediately power off so it is not usable. This is not a battery problem. I am just starting a one year warranty. I have read many reviews with the same complaint mentioned.
I talked to the Pentax tech and he hinted that it was a known defect. However, when I followed the instructions and returned it to Pentax for repair, I was told that a high repair cost would be made (over $152) to repair the misaligned lens shutter casing and do related calibrations. Previously,I could see that the lens cover had shifted slightly as if it were loose so I felt that this was why the lens cover would not open.
The pics were easy to take in the beginning but now I can't use the camera because the cost to repair is about what I paid for it. This camera was treated carefully and was never dropped. There are no scratches or dents. I will never buy a Pentax again. The other complaints said that Pentax Service Dept would not honor their warranty either and said the camera must have been dropped or gotten wet.
Cheap construction which fails and no real warranty provided. It is not worth asking for the camera to be returned to me.
Best Solution
posted on Jul 02, 2006
Very Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1893 votes
Oh boy says the camera tech, a free camera.
UTTER BS mate. This is an old trick to say you dropped it or got it wet. If a camera gets wet you can tell straight away and if you are adamant you haven't dropped it or given it swimming lessons then stand up for yourself and DEMAND it gets repaired. I'll guarantee it'll get repaired and sold very quickly if you leave it with them.
Many cameras suffer from a similar fault and OK many of do get droppped but just as many are faulty without being dropped.
Write letters to Pentax themselves and jump up and down.Make as much noise as you can. If you have a consumer affairs organization write to them as well. Threaten media notification and anything else you can think of. Even legal action. Any genuine Tech will stand up in court and say it's a common fault in many brands.
I did hear of one person who took a camera company to court because they refused to repair her camera because she carried it in her purse. She won because the darned thing was advertised to carried in a pocket of purse.
Honestly some of these shifty characters just love people like yourself. Go to the top and make NOISE and lots of it.
BMW
Was this helpful?
Yes
No
Solution #2
posted on Jul 25, 2007
Helpful)
DocJ
Rank: Apprentice
Rating: 85%, 1 votes
I had same problem, the camera was dropped by my daughter, I could tell by the dent!
Assuming the lens got misaligned so that it would not extend and open the shudder, I firmly placed my fingers on the inner silver ring of the lens (where the printing is)and with pressure, tried to force rotation counterclockwise. After doing this twice, VOILA! The camera is functioning again.
Was this helpful?
Yes
No
Solution #3
posted on Jul 10, 2008
Somewhat Helpful)
dilipbagdi
Rank: Guru
Rating: 87%, 1390 votes
Solution of lens struck :
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
Was this helpful?
Yes
No
Popular Solutions for Pentax Optio S50 Digital
Questions and Unsolved Problems for Pentax Optio S50 Digital
Do you recommend Pentax Optio S50 Digital Camera?
Answer
Answer
Lens will not extend when camera is first turned on. LCD flashes, and lens attempts to rotate and... (More)
Answer
My camrea, won't turn on. I brought it to school, and my friend asked if she could take picture, but... (More)
Answer
the focus on the Optio s50 does not work. THe flash does not activate either
Answer
power source problem camera turns on the shuts down immediately
Answer
I thought the camera was broke. Went looking on this site this morning. I first pressed the reset... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pentax Optio S50 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
