Question about Emerson MW8107WA Microwave Oven
Emerson 1000 wt microwave
Hi there:
My microwave was making a loud humming sound but was not turned on. The top was very hot. I hit the cancel button to no effect. I opened the door and the humming stopped. I closed the door, and the humming started. Opening the door again stopped the buzzing and it remained quiet after closing the door again. Since the top was extremely hot, I unplugged the microwave.
What is wrong?
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
SOURCE: Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Posted on Mar 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: PUSH A BUTTON & PRAY
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jun 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Posted on Apr 19, 2010
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
The MW started to make a loud humming sound and now nothing gets hot at all.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 11, 2011 | Samsung MW1150WA Microwave Oven
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 15, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Loud noise and not heating up
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Apr 26, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
The oven sparks and gives a loud hum during use with plastic food containers. This scares my wife and mom terribly. I have an Emerson 900W microwave oven (model:MW8999SB).
It seems as though the container has a small amount of metal embedded in it ... don't assume just because it is plastic you can put it in the microwave.
Tip ... put just the plastic container in empty and try it. If the plastic get hot then it's the wrong type plastic for a microwave
Oct 02, 2009 | Microwave Ovens
GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Aug 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8107WA Microwave Oven Logo
57 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
