Question about Xerox XG-91D 19" LCD Monitor
XG-19 hello. i read your entry on what you did to fix your xerox monitor and i was wondering if you could give more details of if you have the right steps. i went to radio shack and bought the same amount oof capacity that you mention in your posting. but you said 6 big ones and 1 small. well the capacitors i got from RS dont look like any of the one on the power supply of my monitor so im confused. also teh valtage is higher on teh RS capacitors. My monitor is still open on my table so i can take a picture and email it to you and you can point which ones replace with which. my email address is soliduskal@yahoo.com. I will appreciate if you take the time to help me out. it is a very nice monitor and it would be a shame to toss it. (i paid 425 for it and it has already been sent to xerox to get it fixed fo rthe same issue but now is out of warranty. Thanks very much.
  • Anonymous Dec 07, 2008
    NEEDS PCB-REPAIRED
    U101-U105-U102-U104
    Device AO4606
    Enhancement Mode FET
  • Xerox Master
  • 17,093 Answers
Capacitor Lab Types of Capacitors Radial Electrolytic Capacitors
This explains the different configurations of capacitors. You have the wrong type. The voltage is not that big a deal as long as it is not a huge difference.
Posted on Mar 11, 2017
SOURCE: Xerox XG-91D 19 in. Flat Panel LCD Monitor
Just tore mine apart so here is some help. You need to remove the two screws on the back of the case on the bottom. Then you remove the front cover it slides toward the top of the screen then lifts off. You can pry it off if that doesn't work. If you want to seperate the screen from the back cover you then need to remove the swivel mount and the other two screws from the back cover.
Posted on Jan 04, 2007
SOURCE: Screen goes blank also.
The thing with removing the power from the back of the monitor and holding the Down Button down whilst plugging back in the power does work. My 19inch Monitor was having the same sort of problem. White lines would appear as I turned on the monitor. I did the hard reset on the monitor and it works! I was awed and amazed.
Posted on Nov 26, 2007
SOURCE: Xerox LCD Monitor Won't Power On - PSU Tests OK
I have a flashing light.I am going to replace the PS and I will repost
Posted on Mar 18, 2008
  • 47 Answers
SOURCE: i have a xerox XG-91D and when i power it up there
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 06, 2009
  • 5 Answers
SOURCE: Xerox XG-70D
Remove the 2 screws near the bottom on the back.
Place the monitor face down on a towel with the 2 screw holes near you.
Push the grey plastic back cover away from you whil holding the glass front in place on the towel and the back will lift off easily.
Posted on Aug 17, 2009
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
https://www.youtube.com/watch?v=rkYJS2KhnTc
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ...
Amazon.com: Ac Dc Adapter Charger for Xerox Model 900 ...
www.amazon.com > ... > Monitors
Amazon.com, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
NO PICTURE
These are great monitors but the power supplies have a bad habit of failing. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/xerox-xg-91d-monitor-repair/ That shows what goes out, how to get to the boards and a full parts list to do the repair. If you don't want to do the repair yourself we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 30, 2010 | Xerox XG-91D 19" LCD Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
Nov 12, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in
it look like you need an inverter
Oct 11, 2007 | Xerox XG-91D 19" LCD Monitor
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
82 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
