How to stop test print on Xerox Phaser 6125N?
On the printer press the "Menu" button, then press the down arrow twice and select "Admin Menu" by pressing the "OK" button. Then press down once and select " System Setup". Press the up arrow once and select "Start Up Page". It will probably say "On" and have a * next to it. To turn it off, press down and select "Off" by pressing "OK" again. Make sure that the * shows next to "Off" on the display.
I had the same problem, hopefully this will fix it for you :)
Posted on May 06, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the website. It could be a problem as you machine is no longer sold.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Hello, we are using a 6125n printer in conjunction with Filemaker, and when a print command that involves sending multiple pages is sent to the printer, only the first 3 pages print, and the rest, if...
Does it print blank pages if you try printing to a different printer? Or printing/saving it as a PDF? What are the "parts" to your layout? Is all of the information in the "body"? Are you trying ti print multiple records? Have you done the upgrade ( I'm sorry that I have more questions than answers. If you can provide more detail, I would be happy to help more.
Mar 09, 2011 | Xerox Phaser Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
In the US, a possible source from EBAY is:-|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Mar 31, 2009 | Xerox Phaser 850DP Thermal Printer
6125N won't print in network
If you can address the printer through CentreWare then your halfway there. Is now possible to print a test print via CentreWare if that works look at your p.c, driver setup.
Good luck.
Nov 15, 2008 | Xerox Phaser 6125 Laser Printer
172 people viewed this question
