Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Problem for Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bosch exxcel
By jehar on Oct 20, 2008
Last night when i turned on my dishwasher it tripped the fuses in the house. I have changed the fuse in the plug, but it continues to do it. The lights on the display flash up once and then the fuse box trips again. Not sure what else to check. Can any one give any suggestions?
Same Problem
Mar 10, 2009
-   my bosch dishwasher runs for about 10 seconds then turns all my electric off-   javj
Solution #1
posted on Aug 16, 2009
Not Rated)
cjrepairs
Rank: Wiz
Rating: 84%, 8 votes
either element or probably a leak on the wiring important to get this checked.
Was this helpful?
Yes
No
Solution #2
posted on Jul 21, 2009
Not Rated)
GAZEBO 123
Rank: Guru  Bosch Expert
Rating: 92%, 39 votes
check that voltage suppresor on mains inlet has not failed this will trip electrics even if machine was not running, remove r/h/side panel and check wher mains cable comes into bottom of appliance you can remove this temporarily and machine will run without it they are cheap to replace.
Was this helpful?
Yes
No
Solution #3
posted on Oct 20, 2008
Not Rated)
ashburton
Rank: Wiz
Rating: 82%, 139 votes
The likely cause of this is a failed heater element which would cause the fuse to blow. You will need to get the heater element checked out and replaced if necessary. A visual inspection of the element may reveal the problem jf not an electrical test will be necessary. Be sure to switch off the power before touching the heater element.
Comments:
Oct 20, 2008
- above
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SGS47E02 Exxcel
Questions and Unsolved Problems for Bosch 24 in. SGS47E02 Exxcel
Do you recommend Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher?
Answer
Answer
Bosch exxcel auto option dishwasher 6 years old. Finished the wash programe and then did not turn... (More)
Answer
the top rotating arm has come off its fixedvertical position how does it fix back in place
Answer
Hi I have a bosch sgs47e02 dishwasher which keeps getting stuck mid cycle and won't progress please... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SGS47E02 Exxcel...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
