Question about GE EMO3000 Microwave Oven
Shorting out Hi, My spacemaker is shorting out on most buttons pushed. It will stop after a few seconds and the display panel will read gibberish all across it then it asks you to push clock and set time and date again. At first it was not doing that on every button, so I could try a different one and still get it to heat but now it shorts out every time. A few times I reset it with a previous date rather than todays date and it worked longer before shorting out. What does it need to be fixed? J101
    President:
  • 3,130 Answers
Sounds like the units main elecrtonic control board. You can contact your local parts house for the parts as they should have them or call GE at the #b in the owners manual. I must advise you that there is a very hi voltage inside these microwaves so you must have some know how on working on large appliace and if not PLEASE seek a pro to assit you in this repair. Good Luck
Posted on Jul 02, 2006
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Paper caught fire in microwave. microwave power
check breaker in your home electrical panel...make sure all are on
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL Microwave Oven Model JVM 1430. The pad is unresponsive. When I plug it in I get a line of eights and then the message F 3. What can I do to fix this problem
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
P/N WB27X10165
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave, runs only 2 seconds, then stops
The problem you describe on your JVM1650SH02 is a failing "noisy" magnetron which is emitting electrical interference that disrupts your microprocessor.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You will find a technical sheet hidden behind the grille or behind the controls. It's handy for locating parts and troubleshooting.
You can find an exploded view and parts list by entering your full model number from the tag here, and you can also order parts there.
On your model, you may need to remove the oven from the wall. The installation instructions here will be helpful.
Pro tip: In many GE models, dropping the floor plate that holds the high voltage transformer is necessary to get the magnetron in and out.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Display is reading locked.
Press "Clear/Off" button for about 5 seconds or longer and it will unlock
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Dec 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
See all GE EMO3000 Microwave Oven Questions
Microwave Ovens Logo
138 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
