Question about Krups FBC112 1600 Watts Toaster Oven with Convection Cooking
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
  • maryrice Jan 29, 2009
    I have the same problem the toaster button sticks, also the start button sticks and does not funchtion.
  • 4 Answers
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Posted on Sep 13, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
I had a similar problem, but several of the buttons on my oven were sticking or had to be pressed several times to get them to work. I removed the circuit board, washed it with warm water and soap. Cleaned the panel where the buttons mount to the front of the oven with oven cleaner. Dried the circuit panel and cleaned the button switches with electrical contact cleaner. It now works like new again.
Posted on Oct 31, 2012
Why did the password you just sent me did not work?
Did you cut and paste or enter password manually? Sometimes cut and paste has space not seen.
Mar 02, 2015 | Computers & Internet
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Hello After washing my toaster oven screen that I lay the bread on for toasting, the bread now sticks on it when I toast it
Hi, you may have some detergent or soap left on the screen that is causing the bread to stick to it. Try rinsing it heavily with water to remove any residue. If that doesn't work, try spraying the screen with Pam or a similar non-stick spray.
Oct 07, 2010 | Euro-Pro Toaster Ovens
Cuisinart tob-30bw,is not starting ?when i try to toast its not working
The problem is 4 capacitors on the small circuit boards inside. Three 220uf 16V and one 1uf 50v. These apprear to be going bad from internal heat drying them out and they fail. Symptoms include toast will not start when button pressed, or does start but then stops soon after. A buzz or hum heard when the Toast selection is made..(you should hear nothing until the start button is pressed) and the timer beeper no longer working. These are about $2 in parts, and easy for a good electronics person.
May 06, 2010 | Cuisinart TOB-30 Toaster Oven with...
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Krups FBC112 1600 Watts Toaster Oven with Convection Cooking Logo
601 people viewed this question
Top Krups Toaster Ovens Experts
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
