Question about Frigidaire GSTR1670A Front Load Washer
Softner dispenser the softner doesn't get into the washer at all. It did work for many years and recently off and on. Now not at all. I have removed the cold water hose and cleaned the screen inlet. I have poked an open paperclip into holes that should dispense water to softner dispenser in case they were plugged. Have changed my whole house water filter for better pressure. Have taken out the dispenser and cleaned. Have no idea what to do next. Any help would be appreciated.
  • kris majka Aug 25, 2007
    I did manage to fix softner dispenser. The whole where the water enters the dispenser was clogged. I used a pipe cleaner to get it cleared. It took awhile as there was a lot of gunk there. (I don't know why)
  • Anonymous Feb 10, 2009
    once you pour in the softner it does not cycle through no water goes in dispencer
  • 641 Answers
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Aug 24, 2007
LG washer detergent dispenser won't open The dryer is on top of washer
if you are patient, if you are lucky, you can take a very flexible tool like a frosting spatula and work it into the right hand side of the dispenser drawer and work it back and forth while moving the drawer in and out from its stuck position and maybe get it over the top of the softner tray and free the drawer. the top of the softner is popped up a bit and is catching on the top of the dispenser's enclosure top. about an inch or so in from the right. takes luck, skill and most of all patience. not easy but maybe less work than removing the dryer and going into the top of the washer. (if you get it out, then thoroughly clean everything up, then file down the front of the softner cup so it will not happen again--or throw away the softner cup and stop using softner) GOOD LUCK
Oct 20, 2016 | LG Washing Machines
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE front loading washer softener dispenser does not dispense
After you put your normal softener into the dispenser, top it with water. The remaining water the machine will pour in. You can even try cleaning it with a toothbrush first.
Nov 29, 2007 | GE WSXH208A Front Load Washer
Frigidaire GSTR1670A Front Load Washer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
