Question about HP Officejet J5780 All-In-One InkJet Printer
Prints text backwords on text files
The printer prints all files in reverse (backwards)
    Novelist:
  • 180 Answers
Click on start go to control panel
click on printers and under printer look for the printer icon
right click on the printer icon for your printer and select printing preferences
click on advance and look for mirror image
turn off mirror image and click apply
try to print afterwards
Posted on Oct 21, 2008
Finally fixed mine after corresponding with people at hp and microsoft with no help. I finally deleted my printer then reinstalled. Everything seems to be back to normal.
Posted on Dec 07, 2008
Every time I go to print a single 1 page pdf, my printer prints backwards. How can I get it to stop printing images in reverse?
Open up the printer preferences from "Devices and Printers" and click to print in default settings, then apply and OK
Same in PDF Viewer
Dec 01, 2015 | HP OFFICEJET PRO 8630 eAiO
How do I do mirror (or reverse) printing for a t-shirt transfer? Thanks.
If you are printing text only, you can create it using wordart in word and then use rotate or flip command to reverse the text.
If you are printing a JPG with text, the easiest way will be to use photoshop to edit the image and add text if desired, then use the mirror utility, The picture and text get reversed and the transfer is printed in reverse to become "positive" when you iron it on the Tshirt.
hope this helps.
Mar 07, 2011 | Canon PIXMA MX870 Wireless Office...
Prints photocopies fine but pages of text have lines missing
Run a nozzle check to see if all inks printing out correctly.
Apr 11, 2010 | Epson Stylus DX6050 All-In-One InkJet...
When printing everything prints backwords.????????????
Go to Start printers and faxes. Right click on Hp printer. Go to properties. Go to advanced. Open the printing defaults tab.Open advanced tab.Look for Printer Features : Mirror Image. Set this to no
This should correct your problem.
Hope this helps
Please leave feedback
Nov 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer printing backwords.
1. Go into your printer properties and check all the settings. In the opitons mirror image must have been selected unselect it.
2. If it still won't resolve the problem then you may need to uninstall and re-install the printer.
Note: if you will result to the 2nd solution, make sure that all the printer drivers and software is uninstalled.
Regards,
Nov 24, 2008 | Office Equipment & Supplies
Hello..I have just purchased a now printerc4200 .It works great but the printing starts with the last sheet and runs backwards.....What can I do so it prints sheet 1 first instead of ...
on the driver settting or preferences there is an option to collate print out or option to set to printin reverse order, disable that,on the application when you click file print there should be an option to disable print in reverse order
pls dont forget to rate solution, if you have further inquiries feel free
Apr 07, 2008 | Office Equipment & Supplies
Printing Backwards like a mirror image
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
157 people viewed this question
Ben Johnson
