Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Istuctions for fuel line installation on weed wacker
To install a new fuel line on a weed wacker which line connects to the top port of the carburator ? The one with the filter ??
  • Anonymous May 03, 2009
    i just orderd fuel lines for my craftsman line trimmer need to know which lines go to primmer and which line go to carb
    Scholar:
  • 76 Answers
The esiest way to figure it out is to take the line with the filter and put it on one nipple then push on the primer a few times and see if fuel comes out of the other, if no fuel then switch the line over to the other. But if im not mistaken the filter will go to the bottom.
Posted on Jan 09, 2009
Weed Eater Priming
Check out the tubing to the carb. If it is good then the top part of the carb with the check valves is defective. If so, you need a new carb since those suckers cannot be fixed.
Aug 21, 2016 | Craftsman Weed Wacker Lawn Edgers
How to change the fule line of weed eater?
There should be clamps on either end of the fuel line..1.. empty the fuel out of the weed wacker ..2..loosen the clamps..3..remove the hose ..make sure you are careful when replacing any fuel lines..so you dont puncture a brand new one..tighten the clamps good but not too hard or you can pucturethe hose that way too and make sure its the right one for that model. make sure the line is also fuel resistant..gasoline can eat through the wrong type of line. You should be able to buy the fuel line and clamps at any hardware store:)remember to ask for help from someone in the right department
Apr 14, 2014 | Garden
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
I left gas/oil mixture in my Craftsman weed wacker for too long and now it won't start. Is there a simple way to fix it? I assume the carburator is crudded up. Thanks!
I add fuel stabilizer if fuel is still in mowers, etc. for the winter since it isn't easy to totally drain it.
Just a day ago, our rototiller was limbered up for the garden and I shot 'starter fluid' (ether) into the air intake before even trying it and it fired on the second pull. You can buy the stuff at any auto parts store and even dollar stores.
Mar 20, 2010 | Craftsman 25cc Gas Line Trimmer
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Took tank off weed eater and not sure how the lines go back on
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 19, 2009 | Garden
Gas line needs to go thru buttom of gas tank on sears weed wacker
Take your old line to a lawn mower parts store, ask for a new gas line of the same size. I would buy about a foot long. Push the line in the tank down into the tank(doing this with the tank empty), remove gas cap, turn upside down, a filter and your old line will fall out. Press the new gas line through the hole, push enough through that it comes out of the filler hole, place filter onto the new line, drop into tank, cut off excess and reattach to the carburator.
Aug 06, 2009 | Craftsman 25cc Gas Line Trimmer
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
1,116 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
