Question about Electronics - Others
JVC VHS Cassette adapter C-P7u
Red tab on side does not go flush with adapter. Is it suppose to lock in when tape is inserted into adapter?
  • holibuck Oct 30, 2008
    I changed the battery and it now works.
  • holibuck Dec 10, 2008
    changed battery. works now
How to safely open Micro MC_90 cassette
Posted on Oct 19, 2010
I have this not much used lovely jvc vhs model and it is ejecting the vhs tapes immeditely after inserting them.
I am not an expert on these things.
Could be a problem with the machine; I think there is an optical device that detects the presence of a tape and I hear these sometimes give trouble.
Possibly there is a foreign object inside that is preventing the cassette transport from settling fully into the position where the machine will work.
The cover is usually fairly simple to remove in order to check.
Feb 23, 2016 | JVC Televison & Video
Is a cassette supposed to fit in the cassette adapter
I think the VHS-C (compact?) cassette is suppose to fit inside the JVC CP6U adapter if that is what you're asking?
Jun 28, 2014 | JVC CP6U Adapter
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
I have a jvc compact aamcoder GR-ax 200 i am look for thepart that you put the tape in and insert in in you vcr.
http://www.amazon.com/Maxell-290060-Mechanical-VHS-C-Adapter/dp/B00012F6A6
Go to the above link to find this part from Amazon.com, it is also available at Wal-Mart, Best Buy, Radio Shack or other online vendors. Cost should not be more than $15. It is called a VHS-C adaptor cassette.
May 04, 2011 | JVC GR-AX230 Camcorder
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
How do I know where to attach the cables to upload
since it's an analogue camera and using a standard tape format, you might as well purchase a VHS-C adapter cassette (GB£10 from several photography stores) and run through your VHS VCR into an analogue video capture card.
Jul 16, 2009 | JVC Video Cameras
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not...
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Apr 20, 2009 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
Feb 02, 2009 | Panasonic NV-HS1000 S-VHS VCR
Video to cd or dvd
I am not familiar with this unit, but if it has a analog video output, you can try uploading VHS video to your computer for transfer to DVD
Apr 16, 2008 | Audio Players & Recorders
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
Electronics - Others Logo
4,129 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
