Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher door won't close
Seems to be a problem with the catch on the door. Clip will not budge so we can't close the door. Hotpoint freestanding Aquarius
  • 1 more comment
  • mikestfc Nov 23, 2008
    i have taken the catch apart and found the broken spring but cannot see where it fixes. can anyone help
  • Anonymous Nov 27, 2008
    spring has come out of door catch
  • Anonymous Mar 13, 2014
    hotpoint slim d28 dishwasher
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Posted on Nov 09, 2008
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Help! the door on my dishwasher will not close - problem with top catch?
Yes, it is the top catch i.e. door switch needs replacement.
Dec 30, 2011 | Hotpoint Washing Machines
I have a hotpoint aquarius dishwasher. although the door shuts it will not lock. Sometimes the door will almost shut but the lock seems to jam. Thanks Jim
Possible that this is a mechanical fault. So you might have to remove and clean the lock with a de-greasing spray and close the door few times as you oil it. this might solve the issue.
Please find help on the link below for tips to repair
Dishwasher
Dec 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
Closing handle won't close and lock
if you take the door apart,you will find the catch mechanism,see if none off the springs are broken
Nov 03, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I have a problem with my hotpoint fdw60 dishwasher. The door won'
I think you can fix this yourself if you can see the latch itself. There should be some screws at or near the latch that can be removed. this would allow you to physically get to the latch and check it out. It may be that the latch is broken or loose OR it may be where the latches "catches" that could be the problem also. You are probably looking at an hour's work.
Jan 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher
The dispencer soilnord is broke , change the dispencer.
Nov 09, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
704 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
