Question about Toshiba 55H70 55" Rear Projection Television
Green out of convergence
One day, for no apparent reason, my green was way out of convergence. After much research I learned how to get into service mode. Red and blue are perfect, but the green is way off mostly on the bottom half of the screen. When i try to adjust the green, it will go so far and then seem's to pop way out of alignment. It then adjusts rapidly back down but seems to stop after going so far. Any suggestions?
    President:
  • 3,130 Answers
The green convergence IC is defective. this is not a job for the consumer to do as it requires the experience of soldering and unsoldering and the know how and the safty nissues concerning the HI voltage inside these sets. Please consult a pro to assit you in this matter. Good Luck
Posted on Jul 02, 2006
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Apparent green tube/bulb failure on RCA D52W20
I THINK IT MIGHT BE YOR CONVERSION CHIPS IT COST AROUND 200 TO 250 DOLLARS TO GET IT DONE
Dec 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Jul 31, 2008 | Sony KP-41T65 41" Rear Projection...
Convergence
You need a remote that can produce the "DISPLAY" button on the Sony remote in order to get in service mode....(you could also carefully move the centering rings on the red CRT to line it up with the green CRT)
Jul 17, 2008 | Televison & Video
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Could you tell me how to get into the service menu of my toshiba rear projection tv?
Most TV repair shops have a warranty 30, 60, or 90 days. Call him back. You probably have a convergence IC failing or a resistor changing value in the green convergence output circuit.
Jun 04, 2008 | Toshiba 57H81 57" Rear Projection...
Mitsubishi VS-50705 50 in apparent convergence problem.
First thing a tech would do is solder around Convergence amps then check to see if you can align by menu then if can not. Change amps and maybe resistors.
May 19, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Convergence and such.
GO to www.repairworld.com there might be someone who knows this problem. Hope this might help
Nov 13, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Blue pincushion
Shannon you have a blue convergence failure. this problem can be repaired in home, by a good tv repair guy. John
Sep 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Toshiba 55H70 55" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
