Question about Fuji Finepix F50FD Digital Camera
Fuji F50FD Focus Error
The camera is about 7 months old and the lens will not retract nor will the camera take any pictures. I get a "focus error" code. The camera was not dropped or mistreated in any manner. Of course it is out of the 90 day warrenty and I am wondering if it is worth repairing. Thanks
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
help!!
mine is the exact same way
should i just buy a new cam?
Posted on Apr 01, 2008
SOURCE: s56oo fuju finepix camera focus error
Hit the lens (smack it on you're leg); that seems to be the solution..........
But try cleaning the lens and the AF assistent first!!
Posted on Dec 13, 2008
  • 244 Answers
SOURCE: fuji finepix f50 camera was
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
Posted on Mar 08, 2009
  • 244 Answers
SOURCE: Focus error on Fuji Finepix S5600
See my solution or email for help
Posted on Mar 10, 2009
Hello, I have fuji finepix F50fd camera. It suddenly takes blurred pictures. The lens is clean and there are no messages on the screen. Can't remeber dropping it or damaging it in any way. Regards, Sofia
Welcome to FixYa.
There are three reasons why do you get a blurred images.
1. The camera lens is dirty
- clean the lens with soft and dry cloth
2. AF frame (lit red) and !AF appeared when taking pictures.
- check the focus on the subject and take pictures
3. A small camera icon appeared when taking pictures
- It may cause camera shae. Hold the camera steadily.Use flash photography. A tripod may be recommended, depending on the scene and mode.
Feel free to send us comments or suggestions if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Fuji Finepix F50FD Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
My Finepix 12.0 megapixels camera is having a problem
The focus mechanism is jammed inside the lens. The lens will not retract if any of the slide rings inside the lens are out of alignment.
Read my tips page on my profile under "the only way I know how" for focus, zoom error.
If you can't free it from the out side then you have to open it up and reset it.
my email is on my tips page if I can be of any more help
Oct 06, 2009 | Fuji Finepix F50FD Digital Camera
Taking a picture, I get a focus error message and the lens won't retract.
Try this post:
http://www.fixya.com/support/t2284005-camera_powers_down_when_pressing_shutter
It is probably a battery problem, I had no error but autofocus didn't work. Replacing batteries solved it.
Gus
Jul 28, 2009 | Fuji FinePix E900 Zoom Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
Out of focus pictures on FinePix 50fd
Your lens is stuck, you have two years warranty on this camera, ask your Fujifilm dept in your country or look at the fujifilm support pages.
Regards.
Rob
Apr 16, 2009 | Fuji Finepix F50FD Digital Camera
Fuji finepix f50 camera was dropped with lense out, and now wont return. it also says focus error on screen. I have the same problem and Fuji want £88.00 to repair it - you can buy a new camera for...
Feb 13, 2009 | Fuji Finepix F50FD Digital Camera
'FOCUS ERROR'
If bought this at best buy and are still under your MFG warranty they can send it out to repair, or if you have their service plan, nothing you can do, this needs to be sent to a repair facility...
May 28, 2008 | Fuji FinePix A500 Digital Camera
Fuji Finepix F50FD Digital Camera Logo
93 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
