Question about Acer Aspire 5100 Notebook
Locked keyboard and mousepad on acer aspire 6920G
Suddenly keyboard and mouse pad locked on my laptop. \when i am trying to boot it goes until the windows entry code but then i can not type anything. If i go to bios the keyboard works properly. I tried everything like FN+F11 (Num lock), or FN+F7 (mouse pad lock) but nothing works. I took out the battery and tried to boot only with electricity but again nothing.
I have the laptop 2 weeks now.
Please someone to help me!!!!!!
  • 6 more comments
  • Thanasis Rizopoulos Oct 20, 2008
    First i would like to thank you for your answer. I did this what you prompt me with F8 & safe mode and i had mouse and keyboard. I ask to repair and when this finish i did a restart but the same. Mouse and keyboard doesn't work. Do i have to do something else in safe mode? I would like to remind you that i have Acer Aspire 6920G.
    Please help me!!!!
    Thanks in advance.
    Sorry but i forgot to tell you that mouse and keyboard worked when i choose to proceed for repair from safe mode. If i put safe mode with Networking is the same it goes until windows code input but no mouse no keyboard.
    i have a laptop and i try to use its own mouse pad but not working. The same with the external mouse. I tried many times to plug & unplug it but nothing. The external mouse it works properly with my wife's laptop from where i am writing now. I have mouse and keyboard only to the system recovery options after pressing F8 and to BIOS after pressing F2 on boot up. Any idea?
    Thanks
    Thanassis,
    I don' t have an external keyboard!!!!
    Can someone help me please? Or maybe i have to go straight to acer.
  • Thanasis Rizopoulos Oct 21, 2008
    i found an external keyboard and yes it works. What should i do now???? I can work from the external keyboard.
  • Karthik Jeevan Dec 17, 2008
    I too have ASPIRE 6920G. I am having the same problem. Is anything given in the user manual about this because I don't have it.
    I tried with Fn+Fn7 but it dIdn't work.
    I tried with removing the battery but same continues. Anyone can assist me in this
  • Thanasis Rizopoulos Feb 11, 2009
    FN+F7 for mouse pad lock/unlock.
    If nothing happens then this what i did with mine 6920 was continiously pressing Alt + F10 at boot up for windows formating.
Almost same problem: the mouse froze.
Found a nice solution at another website: switch off the pc, unplug the power supply cable AND remove battery. Press "on" switch for 20 seconds. Now re-install battery, plug back power supply cable, and switch on. Worked for me (what exactly worked for me I don't know but hey)
Good luck.
Posted on Mar 29, 2009
The same thing happened to me and I had to do a system restore. Then tell windows not to auto install new updates. It is totaly a window update driver issue.
Gooooooo.. Vista! YEAH...
Posted on Feb 09, 2009
ACER Aspire 6920 mouse is locked how do I unlock it?
Posted on Oct 21, 2008
  • 45 Answers
Sounds like a Window's driver issue. have you tried Safe mode? Tap F8 (without the FN key) on bootup and select Safe Mode with Networking, your keyboard should work there. Post back with your results
Posted on Oct 20, 2008
  • 1 more comment
  • Arthur Keech Oct 20, 2008
    Try unplugging your mouse and then repeating the same steps. You appear to be having a fairly serious OS issue.
    Hmm, without being able to log into windows we don't have many options. Could you try plugging in an external keyboard (make sure you remove the mouse though). When you reach the login screen press Tab once which should select your password entry section. Hopefully your keyboard will work from there (try both of them). After you get that working post back and I'll tell you what you need to change.
    Ahh shucks... well it looks like your going to need to reformat your computer or get it serviced by a technician. Keep in mind if you format you will lose all of the information on your computer.
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
My mouse pad itsnt working.. wondering if there is a lock on it!
On some laptops, there is a button that is used to disable the mousepad.  Sometimes it is a small button just above the mouse pad that has a light next to it.  Normally when it is off, the light is either red or amber colored.  There is almost sometimes a function button to toggle the mouse pad on and off.  It is normally one of the "f" keys above the numbers on the keyboard, and should have a picture on it of a mouse.  Then there is usually a FN key in the lower left corner of the keyboard.  You have to hold that down, and press the "f" key at the top of the keyboard that has a picture of a mouse on it at the same time.
Mar 30, 2009 | Acer Aspire 5610 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Mouse and keypad don't work in Acer aspire 6920G
It sounds like driver problem. You need to reinstall Windows.
Dec 11, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 6920G keyboard and mouse stop working
yes use your laptop with the battery removed and use it only from the mains.
Oct 21, 2008 | Acer Aspire 5100 Notebook
My acer aspire 5100 as put me into trouble
i had the same problem. apart from keyboard and mousepad, all usb weren't working at all... except the pcmcia slot. so i bought a pcmcia usb card and plugged in the usb mouse and keyboard in those slots. it works! at least on my aspire 5100
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard and mousepad
check the function and F keys on my system the <FN><F9> is the mouse and F5 is the keyboard.
Jun 16, 2008 | Acer Aspire 5100 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Apire 5100
touch pad problem or keyboard short circuit
Oct 17, 2007 | Acer Aspire 5315 Notebook
Acer Aspire 5100 Notebook Logo
713 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
