Question about Bissell 9200 Upright Vacuum
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
My Bissell 9200 ProHeat Cleaner is dispensing water and working otherwise However, it is not sucking out the cleaning solution from the seperate tank.
It's only spraying out plain water but not spraying the cleaner solution.
  • 2 more comments
  • officer28 Nov 20, 2008
    my 9200 will not disperse cleaning solution
  • Anonymous Apr 28, 2009
    I also have the Bissell 9200 and it WILL dispense water, but WILL NOT dispense any solution. Has anyone figured out how to fix this?
    Thanks!
  • Anonymous Mar 15, 2014
    water does not dispense from tank
  • Anonymous Mar 19, 2014
    Bissell lift off deep cleaner won't dispense cleaner
    Problem Solver:
  • 9 Answers
Ensure filters are clean and the soap container straw isn't clogged or bent. After reinstalling shampoo container give it a gentle squeeze which should force some shampoo out and the container to spring back. If it doesn't spring back then there is a problem with pressure release straw. Remove the container, unscrew the cap and check the straw.
Posted on Jul 30, 2016
  • 29 Answers
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Posted on May 29, 2009
  • labelle247 Oct 25, 2010
    Mine will spit out the water and soap, but it does not **** it back up. Does not seem like the pump or else the water would not come out
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Bissell proheat 9200 won't dispense water
Check your filters. Your User's Guide should provide you with location info. Contact Consumer Care at 1-800-237-7691
Jul 17, 2014 | Bissell 2X Proheat 9200 rug cleaner
Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell Proheat 2X Carpet cleaner will not dispense water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 25, 2010 | Bissell 9200 Upright Vacuum
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Power Steamer Proheat Plus not dispensing
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell Pro Heat Turbo will not dispense cleaning solution
heatman101
fss
Dec 05, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9200 Upright Vacuum Logo
1,260 people viewed this question
Top Bissell Vacuums Experts
JDFFEMT
Level 1 Expert
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
