Question about Fisher and Paykel GWL11 Top Load Washer
Eco smart won't drain, smells hot--problem solved
See my other post. i don't see how to move this item to the "solution" section.
  • HiRoller Oct 20, 2008
    problem resolved.
SOURCE: eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Posted on Oct 21, 2008
hi
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paukel washer
might have something stuck in drainage area. see my post on "eco smart won't drain, smells hot" on how to remove motor on bottom of washer.
might also try another website, www.ths.gardenweb.com/forum/laundry to see if anyone on there has an answer.
Oct 13, 2008 | Fisher Paykel EcoSmart GWL15
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Beeps every second, and won't work at all Fisher & Paykel Excellence 7.5 Smart Drive
hi camille
can oyu turn the bowl manually if it is very tight then it is most likely the bearingand it will need tobe serviced
cheers grant
Oct 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Jun 26, 2008 | Fisher Paykel EcoSmart GWL15
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washer not spinning
fisher& paykel eco smart mn gwl11 ser no. myn 603195
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
182 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
